πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
An idea: topography in sketchup (I am not a programmer :-( )
9 Posts 4 Posters 1.9k Views 4 Watching
    pichuneke
    I don't know if it could be possible, because I don't know programming. I did a search with "points" and "cloud of points", but I didn't find anything.
    Well, in my job I have to use a GPS (or a topographic device) to measure a cloud of points. Usually, I have to know the stock of a material (like sand, for example). After doing it, I have to triangulate it with a program. In that sofware, I create a polyline, and I measure the volume inside that polyline. After that I erase all the points inside the polyline (excepts the polyline), and triangulate it again (just with the points of the polyline). I obtain a second volume. The difference between the firs and the second volume gives me the amount of sand I have.
    I contour it sometimes, to make maps. I usually take thousands of points...
    ΒΏCould it be turned into a topographic plugin for Sketchup?
    Consider that is just a question. I have to be sure and I use a reliable software, and I will continue using it for obvious reasons. So I believe that I am losing my time asking you and making you to lose yours by reading my.
    But I believe is an idea, and I wanted to say it here. I don't know why, perhaps I have fun with sketchup and I was thinking of my job πŸ˜‰
    Forgive my spanglish...
    • I Offline
      ilay7k
      look at http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Newest_scripts.html and you can find great D.Bur's cloud-plugin - http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Cloud_V6.zip and use sandbox tools + Bezier Splines -project
      or search in Network - COMPUneering\SimuTerra, old plugin
      i also use indorcad/road tool by indorsoft.ru , but it is russian
        pichuneke
        I have been playing with D. Bur's plugin (I have problems importing my own data at the moment, but sure it works), and I have read about the plugins.
        If someone combine contour + cloud of points + volume measurement, you have a basic topographic plugin... (dxf would be dreaming, of course, for the presentations πŸ˜† )
        I have to do some more work now, but I will study the cloud plugin. Thanks πŸ˜„
          AdamB
          Well funnily enough I wrote the following snippet for calculating volume this morning.
          class Geom;;Point3d
          	def dot(v)
          		self.x * v.x + self.y * v.y + self.z * v.z
          def calculateVolume(container)
          		volume = 0
          	for face in container
          		next unless face.kind_of? Sketchup;;Face
          		volume += (2 * face.area * (face.vertices[0].position.dot face.normal)) / 6
          	volume
            a4chitect
            adamb: great idea, i understand that you calculate the volume as a group of pyramids (bounding faces are the pyramid bases - and all pyramids share 1 top point inside the volume) but is it necessary to multiply by 2 and then divide by 6? wouldn't division by 3 be enough?
            do i understand your script right?
            you have saved the day twice as of now, what's next? (1.light in SU,2. volume formula,...)
              AdamB
              Ah, you spotted my deliberate slowdown so I could come out with v2.0 Damn.
              Yes of course that would be picoseconds faster..
              FWIW, its because I would normally write this as edge1 x edge2 to get the 0.5 the face area, but the good folks at Sketchup already gave me a Face#area call but I neglected to remove the multiply. Or I hadn't had enough coffee.
              Adam
                a4chitect
                πŸ˜†
                this method is usable only for simple shapes (correct me if i'm wrong)
                  AdamB
                  Not sure what you mean by "simple shapes"..
                  If the origin is outside the shape, then the origin-facing faces give a negative contribution, the others a positive so you get the right answer.
                  Not sure what happens with multi-boundary faces, but all this was in the context of a marching cubes point cloud triangulation, so we're good to go.
                    a4chitect
                    i spoke about a case, when a face-origin pyramid is partially inside and partially outside of the calculated shape
                    but maybe since complicated things tend to be trivial once you get the 'clue' after adding all the pyramids together you will get the correct result, forgive me for being sceptic... πŸ˜‰ comparing your and the original 'slicing' method could prove your point
