Toggle between section cuts
For interior scenes I often use section cuts and have to change the view.
It is possible to switch between with a script?
I like to see a script that count a minimum of section cuts, let's say three, which can easily toggle with toolbars buttons. ( The workaround for creating the buttons should possible for me )Burkhard
Though it could probably be done with a ruby, it can surely be done with scenes (and especially when you are using different "views", it can be handy).
Good point Gaius, just forgotten this for the working project. I often have large interior projects, so I don't like to work with scenes. It's always to slow.
You can alway cut down the "transition" between scenes to 0 second so you don't need to wait for long calculations and animations by SU.
I usually have camera scenes, and then scenes that save something else, different section cuts for instance. Different phases on diff. layers, or whatever... so in one cam. I can show 3 diff. phases, 3 diff. section cuts, then move to the next view, and do it all again...very powerful w/ clients and bosses.
