    Moving a curved face/surface
    2 Posts 1 Posters 5.1k Views 1 Watching
    • F
      Frankn
      As the title says, how do I move the curved face/surface? I'm able to iterate and get the individual faces and I tried
      face[0].pushpull distance
      within the loop but the faces take off in different directions.
      I tried
      face[0].transform!(Geom;;Transformation.new([0, distance, 0]))
      but that doesn't work.
      I also tried adding the faces to selection and doing something with that but I can't get anything to work.
      Thanks...
      • F
        Frankn
        Found this post which helped me find the solution...
        https://forums.sketchup.com/t/transform-a-model-vertex-by-vertex/38771/7
        Here's the code I'm using with some notes... if something can be improved or changed please let me know? I can also add the code to iterate the faces if needed?
        Basically you need the vertices of all the faces you want to move and each vertex needs a cooresponding vector to be moved to. That way you can pass the 2 arrays to
        transform_by_vectors(vertices, vectors)
        . Andif you're using sub components like I am, make sure you're in the correct entities context (not sure I'm using all the proper terminology here) oe else you get a mess as a result.
        Like Tig explained in the post I shared...
        ... if every vector has a separate vector-transformation you need to pass two full arrays - in one go!
        vectors=[]  //array of position to move vertices
        vertices=[] //array of face vertices from the individual faces that make up the surface
        vertices.flatten!  //in my case I need to flatten the array
        vertices.uniq!     //make sure there are no duplicate vertex
        vertices.each{|vector|
          position=vector.position.clone
          position.x +=distance
          vectors.push vector.position.vector_to(position)
        component_entity.transform_by_vectors(vertices, vectors)
        Hopefully this helps others out because it wasn't easy to find or understand... but it works!
