HTMLDialog - Change source on the fly? Possible?
I'm just now digging into HTMLdialog usage, as my plugin has kind of outgrown the limited input boxes.
I tried building a test function, which would build my HTML into a string then assign as the source of the dialog. And it works, for the initial page build and show, but after the user picks something from a dropdown and clicks a button to apply the choice, I want the page to re-load with the selected item in the dropdown changing - but after the button is clicked, the dialog seems to re-load with the initial HTML code, or if I try to rebuild the string and reassign the source, I get a blank window.
Can the source of the dialog be re-assigned while the dialog is open?
I've tried to find good examples of how to do this, but all the examples I find seem to be so simple as to not address this, or so over my head they're not much help...Thanks!
Test code below, hope this makes sense... and not too ugly:
module Htmlexample def self.show_dialog model = Sketchup.active_model attrdict = model.attribute_dictionary('BCEWP') usage = 'BldgMod' html = '' html = ' <!DOCTYPE html> <html> <head> <title>Cutlass Dialog</title> <link rel="stylesheet" href="' + Sketchup.find_support_file('Plugins') + '/dialtest/layout.css" type="text/css" media="screen" charset="utf-8" /> </head> <script> function sendDataToSketchUp() { var user_module = document.getElementById("id1"); sketchup.getUserInput(user_module.value) } </script> <body> <div class="content"> <form> <select id="id1" name="modules">' $lastmod = MDAT(0, 'LastUsedBldgMod') attrdict.each { | key, value | if key.to_s.include? "Last" else if key.to_s.include? usage if value.to_s == $lastmod html = html + '<option value="' + value.to_s + '" selected>' + value.to_s + '</option>' else html = html + '<option value="' + value.to_s + '">' + value.to_s + '</option>' end end end } html = html + '</select> <button onclick="sendDataToSketchUp()">Confirm</button> </form> </div> </body> </html>' options = { dialog_title; 'Choose Module', preferences_key; 'cutlass.dynodial', scrollable; false, resizable; true, width; 300, height; 110, min_width; 250, min_height; 70, style; UI;;HtmlDialog;;STYLE_DIALOG } dialog = UI;;HtmlDialog.new(options) dialog.set_html(html) if dialog.visible? dialog.bring_to_front else dialog.add_action_callback("getUserInput"){|action_context, user_module| puts("JavaScript said user_module is #{user_module}.") $lastmod = user_module.to_s MDAT(1, 'LastUsedBldgMod', $lastmod) } dialog.show end #if end end #module -
Did more searching, and found one spot that said the source couldn't be changed (at least not in the way I was meaning). I guess to do what I really want to do, I'd have to dive deep into this, and I just don't have the time since my development work is a "side" project at work.
I DO however have time to use TT's SKUI, so that's what I'm going with, since I have already used it for a couple dialogs already in this project.
