    Converting Su8 ruby 1.86 to Ruby 2
    3 Posts 2 Posters 4.8k Views 2 Watching
    • robintR Offline
      robint
      Is there anyway of replacing ruby 1.86 with ruby 2
      or is that a no no 😮
      As one door closes another one slams in your face
      • Dan RathbunD Offline
        Dan Rathbun
        Very unlikley. Trimble had to compile their own build of Ruby 2.0.0 for SU2014..2016 which had major issues with Unicode character support under Windows. They had to do patching and backporting themselves. The result is fondly called "FrankenRuby" by the SketchUp extensibility team.
        The old versions of SketchUp 2013 (and older) are looking for different entry points in the Ruby interpreter DLL than are used in the Ruby 2+ versions, so you cannot just replace the DLL.
        If your use of SketchUp is still Hobby as your profile suggests, then you can still download SU2016 Make or SU2017 Make. They use Ruby 2.0.0 and 2.2.4 respectively.
        I'm not here much anymore.
        • robintR Offline
          robint
          Hi thanx for the heads up, I thoought I was probably being simplistic 🤢
          Its a pity that SUC does allow more realistic FB to developers. Some of the stuff is brill and I would give 5*
          But I am strictly on the geometric solids/eng side and SU is mainly for graphics and visualisers I guess
