    Construction-demolition linestyle ────x────
    Scheduled Pinned Locked Moved Post Processing
    5 Posts 4 Posters 13.1k Views 4 Watching
    • atelierpaarA Offline
      atelierpaar
      Hello there,
      I am working on construction-demolition plans for a remodeling project.
      According to planning requirements it is necessary to indicate demolished building substance like this
      outlinestyle : ────x────x────x────x────x────
      Color : black
      filling : yellow
      Is it possible to create such a linestyle for SU or LO
      thanks for your comments
      Uli
      • jujuJ Offline
        juju
        Do you have / use Profile Builder 2? You can do it with that.
        If I recall, TIG also has a 2D tool that can do that, but will have to search for it in the PluginStore...
        • utilerU Offline
          utiler
          Yep, can be done with profile builder.... I created a 2D 'Robe' linetype a while back and it works well.
          Should be pretty easy. Actually I might even give it a crack!
          PB linetype.pdf
          PB_Robe Linetype3.wmv
          Just Curious...
          • pbacotP Offline
            I hate planners. Trying to tell you how to draw. The bureaucrats keep squeezing the life out of this work more each year.
            Of course they have had the imagination drained in school, so they can't read a plan unless it's done by proscribed methods that a robot could understand. In fact that's done too, I guess.
            I could go on.
            • utilerU Offline
              utiler
              @pbacot...... WTF?
              Just Curious...
