    Select instances in the selection
    5 Posts 2 Posters 1.6k Views 2 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      **Hello everybody, ☀
      With the code below, it is possible to select an instance in SketchUp by ca definition.
      m=Sketchup.active_model;s=m.selection;m.definitions.each{|d|s.add d.instances if d.name=~/#{"Handle"}/}
      Is it possible to select the instances "Handle # 1", "Handle # 2", "Handle # 3" etc. which are only in the furniture being selected?
      If so how do I do it?
      Thank you in advance for your help.
      David**
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • Dan RathbunD Offline
        Dan Rathbun
        There are some code examples here:
        Selecting Specific Entity, Group or Component (By Name)
        Not sure if it is on the ruby end or if can be done in c. Is there a way to find a specific component in a model by its definition? Also this is from the ruby api. If [0] assumes the first entity, is there a way to get …
        SketchUp Community (forums.sketchup.com)
        These examples use the == but you can use regular expressions:
        http://ruby-doc.org/core-2.0.0/Regexp.html
        begins with: =~ /\A#{name}/
        Or the specific string "Handle" at start of string followed by: an optional whitespace character, underscore or dash; followed by a literal pound sign (which I escape just in case);
        followed by an optional whitespace character; followed by one or more digit characters; just before the end of the string:
        =~ /\AHandle(\s|-|_)?\#\s?\d+\z/
        ... and to make it non-case insensitive we can add a "i" switch at the end outside the slashes:
        =~ /\AHandle(\s|-|_)?\#\s?\d+\z/i
        If you are using Ruby 2.0 or higher you can also use the String#start_with?() method:
        http://ruby-doc.org/core-2.0.0/String.html#method-i-start_with-3F
        inst.name.start_with?('Handle')
        ... or for case insensitive convert to a title:
        inst.name.capitalize.start_with?('Handle')
        I'm not here much anymore.
        • TNTDAVIDT Offline
          TNTDAVID
          **Thank you for all these Dan examples.
          = ~ / # {"name"} /
          It's perfect because it works for all instances.
          Now, I only want to select the instances present in a selection of components.
          The problem is that the code below, selects all the instances in the SketchUp file.
          Thank you**
            Dan Rathbun
            Then use the grep method that TIG showed you to collect all instances in the selection set.
            http://sketchucation.com/forums/viewtopic.php?f=180&t=68172&p=626519#p626479
            Then build an array of definitions for those instances.
            Then unique the array so that each definition reference appears only once in the array. (Or use a set.)
            (And read the several examples in the SketchUp forum thread I pointed to above.)
            https://forums.sketchup.com/t/selecting-specific-entity-group-or-component-by-name/11469
            • TNTDAVIDT Offline
              TNTDAVID
              Thank you Dan.
              I will analyze all your information in detail. 😉
