    No output text on Windows 7 system command
    4 Posts 2 Posters 1.8k Views 2 Watching
      jiva_bagale
      I start an exe from ruby with system ("path\to\exe" "arg1" "arg2")
      When the exe runs, the output text isn't visible in case of Windows 7. It only shows a blinking cursor. The actual task completes fine but no visible text. It works fine on Windows 8 and Windows 10.
      It also shows the text if I run the exe directly on Windows 7.
      One thing I have noticed is the title of the command is "c:\Windows\System32\cmd.exe" on Windows 7 where as it shows the actual path of the exe on Window 8 & 10.
      The output text is important to give feedback to user as sometimes the process can run for up to 1 hour. The SketchUp version is 2017. Ruby version 2.2.4.
      Thanks in advance
      Jiva
        MSP_Greg
        The problem is the ruby build currently included in SU 2017. Not sure why output varies by Windows version.
        If one replaces it with a different build, command output will appear in the console.
          jiva_bagale
          Hi Greg,
          Thank you for the reply. I am not familiar with the ruby side at all. Is the sketchup ruby upgrade simple process. Is there any guide which explain it? A quick google didn't return much useful information.
          Many thanks
          Jiva
            MSP_Greg
            Jiva,
            It's complicated. I started using Ruby years ago with SketchUp. Been away from SketchUp for while, but I'm still using Ruby.
            As I recall, the files get split into two locations, you have to edit the SketchUp.exe file, etc.
            I've also been building Ruby for quite a while, so the files I used were my own and built with current compilers & toolchains. With SU 2017, it can only run with Ruby 2.3 due to the changes that occurred in Ruby 2.4.
            There may be a publicly available build of Ruby 2.3 in the (hopefully near) future...
