    Dynamic Component for holes
    4 Posts 2 Posters 2.3k Views 2 Watching
      I don't see section Dynamic Components so I post here...
      The problem : when the copy of Dynamic Component is made by hand holes are made! 😎
      When the copy of Dynamic Component is made by Dynamic Component itself that works not! πŸ˜•
      Have you some idea about that ? (file linked)
      (it's not for me because I have not the Pro and no possibility to create DC) πŸ˜„
      trou.zip
      • P
        pcmoor
        to create a DC hole that can be copied, one need to double wrap the hole in a cutting DC. Start with the first cutting component as you uploaded add a line, make both a cutting component, enter and delete line. Then the wrapped hole will cut as copied within the outer cutting face
        save as version 7
          Thx i will see that! πŸ˜‰
            Perfect many Thx!
