    A ruby code to display dynamic component
    7 Posts 3 Posters 1.6k Views 3 Watching
      glro
      ...options dialog box
      do you know about any?
      when a dynamic component is introduced in a sketchup model, it is autmatically selected
      it would save time to automatically open the options dialog box too...
        driven
        you need an App Observer that starts a Model Observer that contains an Components Observer that checks for Dynamic Attributes so you can then use a Sketchup.send_action)__if one exists...
        probably easier to set a shortcut key...
          glro
          thank you for trying
          there is no component observer, and there is no sketchupsendaction related to dynamic components...at least i have not find any; i did find an Entityobserver, but it doesn't help...
          a shortcut key would be fine if it was possible to embed it in a ruby code line
            driven
            to get a component, you need to use
            class MyModelObserver < Sketchup;;ModelObserver
              def onPlaceComponent(instance)
               # check it's a DC in here. then trigger the dialog with a win32 call
            but it needs so many other checks as well...
              glro
              i found a way, using autoit
              https://www.autoitscript.com/site/
              this code:
                  SendKeepActive("[CLASS;Sketchup Pro 2017]")
                  ; Simulate entering a string of text.
                      Send("{ALT}")
              		Sleep(500)
              		Send("F")
              		Sleep(500)
              		Send("{ENTER}")
              		Sleep(500)
              		Send("{O}")
              can be compiled with Aut2Exe, and then launched from a plugin
              • Dan RathbunD Offline
                Dan Rathbun
                Taking John's example cross-platform:
                  # ! If the DC extension is ever changed, this example could break !
                    return nil unless defined?($dc_observers)
                    # check if it's a DC in here;
                    if instance.attribute_dictionaries &&
                    instance.attribute_dictionaries['dynamic_attributes']
                      # then set Selection Tool and trigger the dialog;
                      Sketchup.active_model.select_tool(nil)
                      dc_class = $dc_observers.get_latest_class
                      if dc_class.configure_dialog_is_visible
                        dc_class.get_configure_dialog.bring_to_front
                      else
                        dc_class.show_configure_dialog
                      dc_class.refresh_configure_dialog
                âť— This code is fragile, because it deals with someone's else's extension. They could change it (such as method names,) at any time in the future and this example will break.
                I'm not here much anymore.
                  glro
                  i have to work to understand what you wrote, observers a re new for me
                  thank you
                  >       else
                  >       end
                  >     end
                  >   end
                  > end
