    Table
    6 Posts 4 Posters 2.1k Views 4 Watching
    • robertWanR Offline
      robertWan
      Encouraged by Baz's, I'll show how I use SU.
      Table modeled on that:
      Oryginal
      I had done in white gloss.
      The steel structure. Sheathing sheet of 0.6 mm.
      The interior flooded with concrete.
      Outside 3 mm HDF.
      Leg weighed 80 kg.
      The table at the customer
      http://3a-meble.com.pl/nowosci/
      Robert
      view
      down
      inside
      concrete
      STEEL SHEET 0,6 MM
      GLASS FITTING
      HDF 3 mm
      in the middle of doing sanding
      after sanding
      painting - primer
      construction
      gluing HDF
      steel sheet
      painting
      painting
      after painting and sanding and polishing
        davidheim1
        Excellent work on what must have been a very challenging project.
        Best,
        dh
        • cottyC Offline
          cotty
          Impressive work! πŸ‘
          my SketchUp gallery
          • bazB Offline
            baz
            nice, did you CNC the steel from SU?
              robertWan
              Thank you for the kind words. πŸ˜„
              All draw on SU, next to DXF.
              MDF, HDF, wood, etc miling on my CNC.
              Steel they cut me laser.
              Robert
                robertWan
                I found photos of ready-made tables.
