    Staircase builder - strange scaling behaviour - Help!
    4 Posts 2 Posters 1.3k Views 2 Watching
      Deanby7
      I'm trying to debug my staircase builder. When constructing a staircase with winders I've opted to apply a transformation scaling on the whole staircase group in the XY plane to size the staircase to the user input stair width. This produces unexpected scaling results with some elements scaling too little and others too much! I apply the same technique to change to righthand staircase. The script builds a lefthand staircase and the transformation changes it to a righthand one. This works fine!
      I've looked at this for a few days now and can't see how to put this right.
      Stairbug.gif illustrates the problem.
      stairhand.gif illustrates a build of a righthand staircase with success.
      The script is attached, if anyone fancies a challenge! πŸ˜„
      Here's hoping!!!
      db1stairbuilder.rb
      • sdmitchS Offline
        sdmitch
                          #scale up/down all parameters if specifying a non 900mm wide staircase with winders.
                          if (@turns == "Winders") && (@wid !=900.mm)
                            scf = 900.mm / @wid;
                            iscf = @wid / 900.mm;
                            @ris = @ris * scf
                            @nos = @nos * scf
                            @stg = @stg * scf
                            @wid = 900.mm
                            @width = @wid - (@stg * 2) #<----- The only change needed
                            goscale = true
        http://sdmitch.blogspot.com/
          Deanby7
          Thanks for input. I've decided to rewrite the code as the tread "goings" get distorted a bit when scaling the staircase. I should've realised using the transformation scaling was too easy a solution!!
            Deanby7
            Staircase builder fixed!
            Fixed!
