    [Code] Geometry Creation from Excel worksheet data
    6 Posts 2 Posters 2.5k Views 2 Watching
    • Dan RathbunD
      Dan Rathbun
      Here is Marthmatica's example, cleaned up and properly namespace wrapped.
      (ref: http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=23441%26amp;p=589250#p589171)
      Basically if you use it as a template, you replace the outermost namespace module name "Author" with your own toplevel namespace module name. (And you can also rename the plugin module to whatever you wish, as well.)
      I cannot test it currently as I have LibreOffice installed (instead of MS Office.)
      XLTiler_0_2_3.rb
      # encoding; UTF-8
      # Example SketchUp extension; Geometry creation from Excel worksheet data
      require 'sketchup.rb'
      require 'win32ole'
      module Author # outer Author namespace module
        module XLTiler # this particular plugin module
          VERSION = '0.2.3'
          EXCEL = 'Excel.Application'
          @@loaded = false unless defined?(@@loaded)
          class << self # anonymous singleton proxy class instance
            def init()
              @xl = nil
            end ### init()
            def connect_to_excel()
              if @xl.nil?
                # Use WIN320LE.new to start a new spreadsheet instance.
                @xl = WIN32OLE;;new(EXCEL)
              else
                # Connect to an already open spreadsheet application.
                # Use WIN320LE.connect to connect to an already open Excel instance.
                @xl = WIN32OLE;;connect(EXCEL)
              @xl.visible = TRUE
            rescue
              false
            end ### connect_to_excel()
            def get_value(row,col)
              @xl.activesheet.cells(row,col).value
            end ### get_value()
            def get_size( *size )
              @rows = 24 if @rows.nil? # Rows are face count to create
              @cols = 12 if @cols.nil? # Columns have all 4 face points
              # Note cols is the face pts x1,y1,z1; x2,y2,z2... 1 through 4 xyz points; or 12 cols
              # XL row 1= pt1; 1,   1,   0   pt2; 1,   2,   0   pt3; 2,   2,   0   pt4; 2,   1,   0
              # XL row 2= pt1; 2,   1,   0   pt2; 2,   2,   0   pt3; 3,   2,   0   pt4; 3,   1,   0
              # and so on...
              if size.empty?
                # Use defaults
                rows = @rows  # Rows are face count to create
                cols = @cols  # Columns have all 4 face points
                # Now prompt user to change or confirm size;
                begin
                  result = UI.inputbox(["Rows","Cols"],[rows,cols],"Matrix Size")
                rescue => e
                  UI.messagebox(e.message)
                  retry
                else
                  rows, cols = result
              else
                rows, cols = size
              return rows,cols
            end ### get_size()
            # Define the method that is activated from that added menu item click
            def get_xltiler()
              unless connect_to_excel()
                UI.messagebox("Could not connect to Excel !")
                return
              # Instantiate tile matrix origin for Excel rows and columns reference.
              # We'll use a hash whose keys are the integer row numbers. The values
              # will be arrays consisting of #{cols} number of values.
              matrix = {}
              # A return array of faces created;
              faces = []
              # Set row and column count
              result = get_size()
              return if !result # false if user cancelled inputbox.
              @rows, @cols = result
              # rows is how many face tiles you are creating in SketchUp, 1 face tile, per each row
              # BUILD matrix
              # step through all the XL rows
              for r in 1..@rows
                # Each row is an array of #{cols} number of values
                matrix[r]= []
                # In every row populate the matrix from Excel cell values;
                for c in 1..@cols
                  matrix[r] << get_value(r,c)
                # Advance loop to next row.
              # THE MAIN FACE CREATING ROUTINE
              # stepping through rows, as how many tiles you are creating is total rows,
              # then stepping through cols to populate all 4 face pts per row
              # Get handles to our model and the Entities collection it contains.
              model = Sketchup.active_model
              act   = model.active_entities
              group = act.add_group
              cpt   = group.entities.add_cpoint( [0,0,0] )
              # We add a cpoint to keep group from garbage collection
              ents  = group.entities
              pts = []
              for r in 1..@rows
                row = matrix[r]
                pts.clear
                row.each_slice(3) {|ary| pts << Geom;;Point3d;;new(ary) }
                # Add new face per this row;
                ents.add_face( *pts )
              cpt.erase! # no longer needed
              @xl = nil # release Excel reference
              return group # an group of the face objects created
            end ### get_xltiler()
          end # anonymous singleton proxy class instance
          ### RUN ONCE CODE
          if !@@loaded
            # Add a menu item to launch our plugin,
            # in its SketchUp menu default name target,
            # and the name we are giving our function in the "Tools" menu.
            UI.menu("Tools").add_item("Get XLTiler") {
              # UI.messagebox("Ye Excel! come up from hell!")
              get_xltiler()
            init()
            @@loaded = true
        end # this particular plugin module
      end # outer Author namespace module
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        Updated to v 0.2.1
        Changes to get_size() method:
        • Had neglected to assign good results from inputbox.
        • Wrapped inputbox in begin... rescue to trap and retry input type errors.
        • Dan RathbunD
          Dan Rathbun
          Updated to v 0.2.2
          Fixed get_size() method inputbox begin ... rescue block.
          • Added else clause, and moved rows,cols = results statement inside it. (Was attempting to reference results out of scope.)
          Updated to v 0.2.3
          Fixed get_xltiler() method:
          • Fixed call to group.entities.add_cpoint( [0,0,0] )
            (Argument was a list of 3 values. Need to be an Array or Geom::Point3d object.)
          NOTE: There is a faces = [] statement that is unused in the get_xltiler() method. Originally I returned the created faces in an array, but realized they needed to be in a group to prevent unintended geometry interaction. And later,... forgot to remove the statement.
          • P
            picpic020960
            Bonjour ,
            verry intresting !
            i test with excel and SU14 but when i click on tools/get xltiler after load the .rb file
            , exel open and 'matrix size' window appear , and when click this issue
            load 'c:\temp\XLTiler_0_2_3.rb'
            true
            Error: #<TypeError: no implicit conversion to float from nil>
            c:/temp/XLTiler_0_2_3.rb:128:in initialize' c:/temp/XLTiler_0_2_3.rb:128:in new'
            c:/temp/XLTiler_0_2_3.rb:128:in block (2 levels) in get_xltiler' c:/temp/XLTiler_0_2_3.rb:128:in each'
            c:/temp/XLTiler_0_2_3.rb:128:in each_slice' c:/temp/XLTiler_0_2_3.rb:128:in block in get_xltiler'
            c:/temp/XLTiler_0_2_3.rb:125:in each' c:/temp/XLTiler_0_2_3.rb:125:in get_xltiler'
            c:/temp/XLTiler_0_2_3.rb:154:in block in <module:XLTiler>' -e:1:in call'
            thanks for help or little tutorial with all step (excel and sketchup/ruby)
            Regards
            • P
              picpic020960
              OK
              works fine !
              but only read data.
              how to for write data to excel from ruby ?
              other question :
              exists 'macro' recorder as in Excel ?
              thanks
              • Dan RathbunD
                Dan Rathbun
                Try something simple like:
                      def set_value(row,col,val)
                        @xl.activesheet.cells(row,col).value = val
                      end ### set_value()
                @picpic020960 said:
                other question :
                [Do you know if there] exists 'macro' recorder as in Excel ?
                Whatever exists in Excel, and has a built-in VisualBasic interface, can be accessed via WIN32OLE (from Ruby.)
                So, refer to the VisualBasic object model for Excel:
                MSDN: Object model (Excel VBA reference)
