Free GrassHopper inside SU ?
Maybe this online free Nodes Editor LiteGraph can interest you! Ruby coders...
This free Nodes system
@unknownuser said:works in a HTML5 Canvas and allow to export graphs to be included in applications.
Looks very interesting Pilou! I hope someone clever could make it happen.
Author's sub page mentioning collada and litegraph node editor in same piece:
http://www.tamats.com/blog/?p=641
case showing grasshooper-like process
http://www.tamats.com/blog/?p=508 -
That will works fine in Moi3d in no time!
No reason that works not in SU!By Max Smirnov
For the fun you can make your own free solid parametric modeler online!
http://floodeditor.comOf course for all that you must be a nodes lovers!
pilou! WOW!
yes I could see myself modelling with a node base system...
do these systems only work with solid modeling software?
As
you can script your own nodes
you can script or code some things for make the real bridge, this can work for any thing!
In local or online
(some work and learning curve can also existing!
