    Start_operation and commit_operation issue
    5 Posts 2 Posters 647 Views 2 Watching
      Garry K
      I've run into a wierd situation where the status from start_operation and commit_operation is good yet the first time through the undo doesn't behave as expected.
      Instead of undoing all the various operations - the undo is 1 step at a time - just as if there wasn't a start and commit.
      The second time through with the plugin and it works as expected.
      Too much code to show. Question is if anyone has run into this kind of thing.
        driven
        there are reports of this with embedded operations...
          Garry K
          I've read lots of reports about start_operation and commit.
          But nothing about specifically first time through failure.
          Maybe it is how I'm searching history.
            driven
            It may not be your issue, but the most resent I know is found on the dark side....
            Difficulties wrapping the operations of a plugin into one undo
            I’ve written a plugin which is based on the parametric class. My plugin creates two classes depending on the parametric class. parametric’s create and edit methods have start_operation/commit_operation functionality buil…
            SketchUp Community (forums.sketchup.com)
              Garry K
              Sorry,
              Start and commit are not nested. A few lines of debug code proves that.
              Still at a loss.
