    Detect whether all elements of the model intersect
    10 Posts 3 Posters 981 Views 3 Watching
      CEIT81729
      I want to detect whether all elements of the model intersect
      Like this, but I have no solution, please give me advice, Thank you very much!
      p = mod.entities.find_all {| ent | ent.is_a (Sketchup :: ComponentInstance)?}
      bb = p.bounds.intersect (p.bounds)
      if bb.valid?
      if p.description == "one"
      p.get_attribute ("dynamic_attributes", "name")
      else
      puts "B"
      else
      puts "no"
      • sdmitchS Offline
        sdmitch
        if bb.valid?
        else
        puts "B"
        else
        puts "no"
        bounds.intersect results are unreliable and can return a valid boundingbox even when bounds do not overlap as demonstrated with this code. In these cases when bb is valid, the x,y or z coordinate of a bb corner will be 1.0e30 in magnitude.
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        grp = sel.grep(Sketchup;;Group)
        for i in 1...grp.length
         bb=grp[0].bounds.intersect(grp[i].bounds)
         if bb.valid?
          puts "#{grp[0].name} and #{grp[i].name} intersect"
         else
          puts "#{grp[0].name} and #{grp[1].name} do not intersect"
        http://sdmitch.blogspot.com/
          CEIT81729
          Hello sdmitch:
          First of all, thank you for teaching, I changed your code to meet my needs.
          Please look at this picture, ruby console return
          "one and two intersect
          one and three do not intersect"
          so I also want to know how to return
          "two and three intersect"
          Need to write a loop(for...end)?
          Because I want to deduct the intersection surface of the overlapping area,
          so I need to detect whether all elements of the model intersect.
          Thank you for teaching again.
            driven
            without needing a pre-selection, something like this should return all combinations...
            But it will return two for each pair i.e. a=b and b=a...
            ent = mod.entities
            grp = ent.grep(Sketchup;;ComponentInstance)
            for i in 0...grp.length - 1
             grp.each{ |g| next if g == grp[i] # skip comparing to self
                           bb = Geom;;BoundingBox.new.add(g.bounds.intersect(grp[i].bounds)) # @Sam, does this avoid that error?
                           if bb.valid?
                              puts "#{g.name} and #{grp[i].name} intersect"
                            else
                              puts "#{g.name} and #{grp[i].name} do not intersect"
                          bb.clear
            • sdmitchS Offline
              sdmitch
              @ceit81729 said:
              Hello sdmitch:
              Yes, a second For loop is needed.
              sel = mod.selection
              for i in 0...grp.length-1
                for j in i+1...grp.length
                  bb=grp[i].bounds.intersect(grp[j].
                  if bb.valid?
                    puts "#{grp[i].name} and #{grp[j].name} intersect"
                  else
                    puts "#{grp[i].name} and #{grp[j].name} do not intersect"
              In your example with the groups aligned with the X axis, the code works perfectly but returns a valid bb even if the groups are only touching and not overlapping. Perhaps this is desired. If you rotate them so that they are on the Y or Z axis, a valid bb is returned in all cases. So a different or additional test may be needed.
                driven
                @Sam...
                it was working for me so I checked the docs...
                Your still on v14?
                Note: Prior to SU2015 this method would return incorrect result in some cases. For correct result in these versions you must first check if the boundingboxes actually overlap - then call this to get the resulting boundingbox.
                • sdmitchS Offline
                  sdmitch
                  @driven said:
                  @Sam...
                  Your still on v14?
                  Yes I am unfortunately.
                  Some how I missed that note!
                    driven
                    this seems to offer solution...
                    http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=29156#p254014
                    • sdmitchS Offline
                      sdmitch
                      Yes, that seems to work.
                        CEIT81729
                        Hello everyone
                        I reference everyone's suggestion
                        The successful implementation of the following code:
                        ent = mod.entities
                        grp = ent.grep(Sketchup::ComponentInstance)
                        bb = Geom::BoundingBox.new.add(g.bounds.intersect(grp[i].bounds))
                        if bb.valid?
                        puts "#{g.name.to_s} and #{grp[i].name.to_s} intersect"
                        else
                        puts "#{g.name.to_s} and #{grp[i].name.to_s} do not intersect"
                        bb.clear
                        Next, I want to know how to calculate the model of dynamic properties of all objects (such as "Lenx", "Leny" ,"Lenz"...etc) after the object intersected the other object.
                        The case description like this:
                        First, detect all objects intersect situations like the above code
                        Second, if name = "column" objects intersect name = "beam" objects(just a simple example)
                        then, "column" objects dynamic properties("Lenx") deduction "beam" objects dynamic properties("Leny")
                        Thank you for your advice and help πŸ‘
                        Collision detection
                        Objects dynamic properties
