    Getting bent
    4 Posts 3 Posters 1.3k Views 3 Watching
      davidheim1
      I've wanted to model a bentwood chair for quite a while, and finally managed to do it last week. This is the B9 armchair, by August Thonet. It turned out to be quite an exercise with SketchUp's native tools and a plugin.
      I began with a circle inscribed in a square to represent the seat. I pushed this component to the thickness I wanted and moved it up to its proper height. That was my anchor point for positioning all the bent parts.
      To make the arm, I followed a technique Dave Richards used to make a barrel chair. You can see it here:
      http://www.finewoodworking.com/item/111204/a-barrel-chair-a-follow-me-lesson-pt-1
      The rear legs bend in two planes and proved the hardest to model. I spent a couple of days trying to make Chris Fullmer's Shape Bender plugin do the bend. When it finally dawned on me that Shape Bender wasn't the right tool, I drew two shapes--one for the front-to-back bend, one for the left-to-right curves--intersected them, and used the intersection line as the path for Follow Me. I had to repeat that exercise two or three times until I got a satisfactory curve.
      Everything else was relatively easy. I shaped the seat with Push/Pull. And I went back to Shape Bender to make the curved and tapered front legs.
      I've uploaded the model to the 3D Warehouse. You can find it here:
      https://3dwarehouse.sketchup.com/model.html?id=u35f186af-b9bc-439f-adbc-29d0f36850fe
      Enjoy.
      Best,
      dh
      • cottyC Offline
        cotty
        Nice, I think you shouldn't wobble to much with this one πŸ˜‰
        my SketchUp gallery
        • JQLJ Offline
          JQL
          One of my favourite chairs from all times!
          I've been collecting old thonet chairs from garbage cans and garages for as long as I can remember (only managed one original)!
          My Thonet Rocking Chair rocks!
          www.casca.pt
          Visit us on facebook!
            davidheim1
            Thanks, Cotty. The chair is pretty well grounded.
            Like you, JQL, I've always admired Thonet chairs. They're so simple and graceful.
