    Include paths
    3 Posts 2 Posters 478 Views 2 Watching
      PeeWeeHaa
      Hi guys,
      I am pretty new to Sketchup, RubyScript and webdialogs and i encounter an issue with writing webdialogs. Not sure if this is the correct forum to post, but feel free to correct me...
      I am writing a webdialog that edits data and i need to include an external css script and library. I can manage that with a relative path using something like
      <link rel="stylesheet" href="../../../resources/css/webdialogs.css" />
      I would like to include it with an absolute path, something like
      <link rel="stylesheet" href="<myroot>/resources/css/webdialogs.css" />
      Is there a way to get this root from within the webdialog?
      • Dan RathbunD Offline
        Dan Rathbun
        BASE element | base object
        [https://msdn.microsoft.com/en-us/library/ms535191(v=vs.85).aspx](https://msdn.microsoft.com/en-us/library/ms535191(v)
        ... but it is more normal to have your plugins resources in a sub-directory of your plugin's sub-directory.
        I'm not here much anymore.
          Dan Rathbun
          IN Ruby you can do interpolation in double-quoted strings with the #{ } operator. The expression between the curlies is evaluated and passed to the result's to_s method, then stuffed into the string.
          So you'd create a string of html:
          html = %Q{
           <html>
              <head>
                <base href="#{myroot}" />
                <link rel="stylesheet" href="resources/css/webdialogs.css" />
              </head>
              <body>
              </body>
           </html>
          my_dialog.set_html(html)
          You can also use a HEREDOC.
          See: http://ruby-doc.org/core-2.0.0/doc/syntax/literals_rdoc.html
