    Importing don't have to bring inherit of lenz
    2 Posts 1 Posters 319 Views 1 Watching
    • kimpastroK Offline
      kimpastro
      Hi again everyone.
      I thought that had finished my import tool... but.. found a "bug". I have a situation, as follows:
      *Note: Not sure about the name of the things yet.. When I say entity I mean a rack, shelf, desk, table or anything that is a full mounted object.
      When create an entity with LenZ 700mm, put another entity on your side with LenZ 400mm, then export all, everything is save with correct attributes. But, when I import, the second entity assume LenZ = 700mm. The both assume the same height.
      But if I change the order of put entities (400mm first, then 700mm after), when Import, everything occurs as it meant to be, with the respective LenZ.
      Here's my import code:
        loaded_module = Sketchup.active_model.definitions.load_from_url uri
        moduli['attributes'].each do |key, value|
          my_load_texture_method
          loaded_module.set_attribute 'dynamic_attributes', key, method_to_inches_mm_etc(value)
        my_method_to_set pos_x, pos_y, pos_z and rot_z
        t_rotation = Geom;;Transformation.rotation(ORIGIN, Z_AXIS, rot_z.degrees)
        point = Geom;;Point3d.new pos_x, pos_y, pos_z
        t_position = Geom;;Transformation.new point
        entities = Sketchup.active_model.active_entities
        instance = entities.add_instance(loaded_module, t_rotation)
        instance.transform!(t_position)
        $dc_observers.get_latest_class.redraw_with_undo instance
      What I could observe is that, SU execute a rotation in ORIGIN, then apply texture and high(at this point he puts the wrong LenZ attribute), then move to his position.
        kimpastro
        well.. that's embarrassing...
        actually the "problem" is that i had overloaded "onElementAdded" method.. and put:
        @service.recent_inherit! entity
        now i send a new attribute, then it becomes:
        if entity.definition.get_attribute 'dynamic_attributes', 'imported_entity'
        sorry about that and thanks for your time.
        cheers.
