    Load classification system via ruby code
    18 Posts 7 Posters 3.4k Views 7 Watching
    • icehuliI Offline
      icehuli
      Thanks Aerilius,
      Thanks tt_su,
      I am waiting for the next release. 😎
      Anyway it is nice to see that SketchUp is on the way to BIM.
      I have figured out how to add a classification to an entity, just in case that anyone would like to try the [highlight=#ffff00:3oppyo7z]undocumented[/highlight:3oppyo7z] API function " add_classification".
      group.add_classification 'IFC 2x3', 'ifc;IfcBeam'
      • brewskyB Offline
        brewsky
        @tt_su said:
        The classifier system was such a big change that it was in the works close uptil release which didn't leave us with enough time to implement a proper API for it.
        Ah! Too bad... That's why I couldn't find it in the documentation. πŸ˜‰
        I really would like to have API access to the new classifiers.
        Apart from the existing unofficial :add_classification and :remove_classification I would also like to have a :get_classification method.
        Cheers!
        Jan
        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
        • tt_suT Offline
          tt_su
          Yea, the method set was incomplete which is why we never documented them. Once there is a complete set we'll document them and make them part of the API. At the moment, if you use them, keep in mind they could change - so keep any eye on breaking changes in next release.
          • Z Offline
            zilony
            So we have a new version. Has anything changed on the classification and the API?
            • tt_suT Offline
              tt_su
              Yup! πŸ˜„
              http://www.sketchup.com/intl/en/developer/docs/releases
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/classifications
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/classificationschema
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/componentdefinition#add_classification
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/componentdefinition#remove_classification
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/componentdefinition#get_classification_value
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/componentdefinition#set_classification_value
              • blruuskaB Offline
                blruuska
                Not able to set enumerated "choice" type attributes via the API. For example, the IFC 2x3 CompositionType for IfcBuilding provides the values "complex", "element", or "partial". It can be set manually with the UI, but not the API:
                selection = Sketchup.active_model.selection
                definition = selection.first.definition
                definition.add_classification("IFC 2x3", "IfcBuilding")
                path = ["IFC 2x3", "IfcBuilding", "CompositionType", "IfcElementCompositionEnum"]
                success = definition.set_classification_value(path, "element")
                Error; #<RuntimeError; Unexpected attribute type>
                <main>;in `set_classification_value'
                <main>;in `<main>'
                SketchUp;1;in `eval'
                Am I doing something wrong, or is this kind of value setting not yet available in the API?
                • Dan RathbunD Offline
                  Dan Rathbun
                  I think classification features are Pro edition ONLY of SketchUp version 2015 ?
                  The API says:
                  ... which says:
                  • Raises NotImplementedError when trying to set the value of "choice" attributes.
                  • Raises RuntimeError if the attributes being set are corrupt.
                  • Raises TypeError when trying to set a value that is not valid for the attribute.
                  That looks like a "choice" attribute. The API doc is incorrect on the exception class being raised, but it looks like setting these kind of attributes is not yet implemented.
                  I even tried a ordinal integer without success. The same exception occurs.
                  I'm not here much anymore.
                  • blruuskaB Offline
                    blruuska
                    Dan, Thanks for verifying. It is surprising that NotImplementedError wasn't raised, if that is the case here.
                    • brewskyB Offline
                      brewsky
                      πŸ˜„ HaHa!!!
                      I just found out that classifications are stored as nested attribute dictionaries!
                      That means you can set classifications(if you're a bit careful) using the "normal" way with "set_attribute", I guess even in the free version...
                      A "IfcBuilding" for example gets an attribute dictionary called "IFC 2x3" which gets a nested attributedictionary "CompositionType" which gets a nested attributedictionary "IfcElementCompositionEnum" in which "value" can be set as "partial"
                      Cheers!
                      Jan
                        Dan Rathbun
                        @brewsky said:
                        A "IfcBuilding" for example gets an attribute dictionary called "IFC 2x3" which gets a nested attributedictionary "CompositionType" which gets a nested attribute dictionary "IfcElementCompositionEnum" in which "value" can be set as "partial"
                        Oh that is correct... I forgot that. (Don't interact with classifications much myself yet, via code.)
                        But... the actaul value in the nested dictionary is a string "partial" ?
                        Ie, not the integer of the choice ?
                        How would coders check if a value was one of the proper choices ?
                        It looks like not much but the name, namespace and the <=> sort comparison operator have been exposed for the ClassificationSchema class.
                        They have not exposed the filepath to the schema file from which it was loaded, so coders would need to go try to find skc & xsd files that match, in order to do their own XML parsing.
                        • brewskyB Offline
                          brewsky
                          Yes indeed, a string. There is another atribute called something like "options" which contains a list of valid options (as strings). The entire classification scheme that goes with the selected ifctype(ifcBuilding) is stored inside the componentdefinition. So you can check validity right from the definition without having the original source scheme.
                          • blruuskaB Offline
                            blruuska
                            Ah, very interesting, thanks brewsky!
                              Dan Rathbun
                              Oh that is right. I remember now. I did not like this when I realized it.
                              This is going to bloat model files.
                              Why did they leave them in each definition, when they could have attached only one schema to the definition list that needy definitions could reference? (rhetorical)
                              I realize they must be saved into components for 3DW & local libraries, but ...
                              • brewskyB Offline
                                brewsky
                                Yes, I'm glad they DO store the scheme inside the model so you don't have to redistribute it seperately, but more than one "copy" in the model indeed seems bloated.
                                I'm curious what happens when you upgrade a model from IFC 2x3 to 2x4(when a scheme is available). I'm affraid you would have to re-assign every single property... and manually remove the old scheme to get rid of the duplicate classifications.
                                • tt_suT Offline
                                  tt_su
                                  Ackh! Yea, something is amiss here. Not sure if we intended to support enumeration type in the initial release of the API - but if that's the cause it should have been NotImplemented. However, I might confuse this with the "choice" type. Maybe something changed in the last moment. I need to investigate.
