Need help with hinges
Hi! Im kinda new with SketchyPhysics and would appreciate any help. Im trying to make a simple murphy bed model with desk and i am having problem with the joints.
The way it works is if the bed is folded up the the table is set and when you put down the bed the table acts as a leg. I have attached my file. please disregard the measurements, i just want to learn how to do it and where I am making the mistake.
Thank you in advance for your help!
I have changed the wall into a group and physically static, the bed into nonstatic and the table into a box... Please try it.
Thank you! It works fine. If you dont mind me asking, what does making the desk as a box do?
Due to the inhomogeneous internal structure of the table - groups, surfaces, lines, etc. - the table is sinking into the ground, if you use the Default setting. With the setting Box everything works OK. Try it ....
