    Making submenu
    7 Posts 3 Posters 685 Views 3 Watching
      kmk111890
      I am a beginner in learning Sketchup with Ruby. Now, I am practicing coding from existing .rb files. Below code is one of examples. You will be able to place the figures in .skp on cartesian space if you run this script(you need .skp files, images for making icons).
      I would like to run this script in another way, submenu. I hope all figures are placed wherever i want after selection in input box, not clicking icons. It will be my pleasure if you give advices.
      ` require 'sketchup.rb'
      class FGsystem
      def FGsystem::reset_global_variables
      @status_prefix=""
      def FGsystem::set_none_params(e,dist)
      FGsystem.set_default_(e,dist)
      dict_name="FGsystem"
       dict_key_attenuation = e.get_attribute(dict_name, " ")
      def FGsystem::set_30m90d_params(e,dist)
      FGsystem.set_default_30m90d(e,dist)
      dict_key_attenuation = " " if dict_key_attenuation==nil
      dict_key_radius =@spothot if@spothot!=nil
      dict_key_falloff = @spotoff if @spotoff!=nil
      def FGsystem::set_50m60d_params(e,dist)
      FGsystem.set_default_50m60d(e,dist)
      def FGsystem::set_default_none(e,dist)
      if !e.attribute_dictionary dict_name
      dict_key_animate = " "
      def FGsystem::set_default_30m90d(e,dist)
      def FGsystem::set_default_50m60d(e,dist)
      def FGsystem::status_bar(stat_text)
      statbar = Sketchup.set_status_text(@status_prefix + stat_text)
      def FGsystem::instert_none
      Sketchup.active_model.select_tool FGdrawing.new("none.skp")
      def FGsystem::insert_30m90d
      Sketchup.active_model.select_tool FGdrawing.new("30m_90degree.skp")
      def FGsystem::insert_50m60d
      Sketchup.active_model.select_tool FGdrawing.new("50m_60degree.skp")
      class FGdrawing
      def initialize(comp)
      FGsystem.reset_global_variables
      @ip1 = nil
      @ip1 = nil
      @drawn=false
      @compname=comp
      model=Sketchup.active_model
      status=model.start_operation(" ")
      model.commit_operation
      def activate
      @ip = Sketchup::InputPoint.new
      @ip1 = Sketchup::InputPoint.new
      @ip2 = Sketchup::InputPoint.new
      FGsystem::status_bar(" ")
      self.reset(nil)
      def deactivate(view)
      view.invalidate
      def onMouseMove(flags, x, y, view)
      if @state==0
      @ip.pick view, x, y
      if( @ip != @ip1 )
      view.invalidate if( @ip.display? or @ip1.display? )
      @ip1.copy! @ip
      view.tooltip = @ip1.tooltip if( @ip1.valid? )
      else
      @ip2.pick view, x, y, @ip1
      view.tooltip = @ip2.tooltip if( @ip2.valid? )
      view.invalidate
      def onLButtonDown(flags, x, y, view)
      if (@state==0)
      @ip1.pick view, x, y
      if( @ip1.valid? )
      Sketchup::set_status_text "Select none's range", SB_PROMPT if (@compname=="none.skp")
      Sketchup::set_status_text "Select 30m90d's target", SB_PROMPT if (@compname=="30m_90degree.skp")
      Sketchup::set_status_text "Select 50m60d's target", SB_PROMPT if (@compname=="50m_60degree.skp")
      @state=1
      elsif (@state==1)
      if(@ip2.valid?)
      self.create_light(view)
      self.reset(view)
      @state=0
      def draw(view)
      if( @ip1.valid? )
      	if( @ip1.display? )
      		@ip1.draw(view)
      		@drawn = true
      if( @ip2.valid? )
      	@ip2.draw(view) if( @ip2.display?)
      	length = (@ip1.position.distance(@ip2.position)).to_m
      	self.draw_geometry(@ip1.position, @ip2.position, view)
      	@drawn = true
      def onCancel(flag, view)
      mod=Sketchup.active_model
      mod.select_tool nil if @state==0
      self.reset(view)
      def reset(view)
      @state = 0
      @ip.clear
      @ip1.clear
      @ip2.clear
      if( view )
      view.tooltip = nil
      view.invalidate
      @drawn = false
      def draw_geometry(pt1,pt2,view)
      view.set_color_from_line(pt1,pt2)
      view.line_stipple="-.-"
      view.line_width = 1
      view.draw(GL_LINE_STRIP, pt1, pt2)
      view.invalidate if @drawn
      def create_light(view)
      pt1=@ip1.position
      pt2=@ip2.position
      definitions=model.definitions
      path=Sketchup.find_support_file(@compname,"Plugins/FGsystem")
      definition=definitions.load(path.to_s)
      model.start_operation("Insert Light")
      light=model.active_entities.add_instance(definition, @ip1.position)
      vector=pt1 - pt2
      vector2=vector.clone
      vector2.length=1
      pt1=pt1-vector2
      vector2=vector
      vector2=Geom::Vector3d.new(0,0,1) if @compname=="none.skp"
      trans=Geom::Transformation.new(pt1,vector2)
      light.transformation=trans
      dist=vector.length.to_m
      FGsystem.set_none_params(light,dist) if @compname=="none.skp"
      FGsystem.set_30m90d_params(light,dist) if @compname=="30m_90degree.skp"
      FGsystem.set_50m60d_params(light,dist) if @compname=="50m_60degree.skp"
      if( not file_loaded?(FILE) )
      UI.add_context_menu_handler do |menu|
      dir= File.dirname(__FILE__)
      cmd_array = []
      cmd = UI::Command.new(" ") {FGsystem.insert_30m90d}
      cmd.large_icon = cmd.small_icon = dir+"/FGsystem/kt_spot.png"
      cmd.status_bar_text = cmd.tooltip = "30m90d"
      cmd_array.push(cmd)
      cmd = UI::Command.new(" ") {FGsystem.insert_50m60d}
      cmd.large_icon = cmd.small_icon = dir+"/FGsystem/kt_scene.png"
      cmd.status_bar_text = cmd.tooltip = "50m60d"
      cmd_array.push(cmd)
      tb = UI::Toolbar.new("FGDetector")
      cmd_array.each {|i| tb.add_item(i)}
      tb.show if tb.get_last_state == -1
      file_loaded(FILE)`
      • sdmitchS Offline
        sdmitch
        if( not file_loaded?(__FILE__) )
        sub=menu.add_submenu("FGsystem Insert")
        sub.add_item("30m90d") {FGsystem.insert_30m90d}
        sub.add_item("50m60d") {FGsystem.insert_50m60d)
        end#do
        end#if
        http://sdmitch.blogspot.com/
        • Dan RathbunD Offline
          Dan Rathbun
          (1) Never define classes at the toplevel (within the global ObjectSpace.)
          (2) Since you will likely be writing more than 1 (one) plugin, wrap each plugin in a sub-module.
          Example how to wrap your classes & plugins like so:
          module KMK # toplevel author/company namespace module
            module FG # plugin namespace module
              class Drawing
              class System
              unless file_loaded?(__FILE__)
               # code to run only during load ...
              end # unless loaded
              file_loaded(__FILE__)
            end # module plugin FG
          end # module toplevel KMK
          (3) Each of you plugin folders should begin with your toplevel module name, such as "KMK_", or whatever you choose. (This is required by the Extension Warehouse using the SketchupExtension class.)
          (4) use self::method_name() to define class methods and module functions, so you do not need to rename them all, if you decide to (or must) change the name of the class or module.
          Here's an example for the run once block:
                cmd_array = []
                menu_text = "FGDetector"
                item_text = "30m90d"
                cmd = UI;;Command.new(item_text) { System.insert_30m90d }
                cmd.large_icon = cmd.small_icon = "#{dir}/KMK_FGsystem/kt_spot.png"
                cmd.status_bar_text = cmd.tooltip = item_text
                cmd.set_validation_proc {
                  MF_ENABLED
                cmd_array.push(cmd)
                item_text = "50m60d"
                cmd = UI;;Command.new(item_text) { System.insert_50m60d }
                cmd.large_icon = cmd.small_icon = "#{dir}/KMK_FGsystem/kt_scene.png"
                  MF_ENABLED
                cmd_array.push(cmd)
                tb  = UI;;Toolbar.new(menu_text)
                submenu = UI.menu("Plugins").add_submenu(menu_text)
                # [a] The context menu is built EACH time the user clicks the right-mouse button.
                UI.add_context_menu_handler do |pop|
                  # You can wrap the following lines within
                  # a conditional expression, to control
                  # if your popup context menu is shown.
                  subpop = pop.add_submenu(menu_text)
                  cmd_array.each {|i| subpop.add_item(i) }
                # [b] So the normal menu and toolbars must be registered separately!
                cmd_array.each do |i|
                  tb.add_item(i)
                  submenu.add_item(i)
              end # unless loaded
          I'm not here much anymore.
            Dan Rathbun
            Use String interpolation operator #{} to stuff variable data into strings.
            Like: "#{dir}/KMK_FGsystem/kt_spot.png"
            (The above creates 1 string object.)
            This: dir + "/KMK_FGsystem/kt_spot.png"
            creates an extra new string object, which is slower.
            (See the doc for the String class +() instance method.)
              kmk111890
              I tried to fix some lines, but It still didn't work except that submenu is created. Nothing shown up on space once I clicked the submenu. Is it right the name of folder in plugins has to be 'KMK'?
              module KMK
              module FG
              class FGdrawing
              @ip1 = nil
              @ip1 = nil
              @drawn=false
              @compname=comp
              def activate
              self.reset(nil)
              view.invalidate
              if @state==0
              @ip.pick view, x, y
              if( @ip != @ip1 )
              @ip1.copy! @ip
              else
              view.invalidate
              if (@state==0)
              if( @ip1.valid? )
              @state=1
              elsif (@state==1)
              if(@ip2.valid?)
              self.reset(view)
              @state=0
              def draw(view)
              if( @ip1.valid? )
              	if( @ip1.display? )
              		@ip1.draw(view)
              		@drawn = true
              if( @ip2.valid? )
              	@drawn = true
              self.reset(view)
              def reset(view)
              @state = 0
              @ip.clear
              @ip1.clear
              @ip2.clear
              if( view )
              view.tooltip = nil
              view.invalidate
              @drawn = false
              view.line_width = 1
              pt1=@ip1.position
              pt2=@ip2.position
              path=Sketchup.find_support_file(@compname,"Plugins/KMK/FG")
              vector=pt1 - pt2
              vector2.length=1
              pt1=pt1-vector2
              vector2=vector
              class FGsystem
              @status_prefix=""
                cmd_array = []
                cmd = UI::Command.new(item_text) { FGSystem.insert_30m90d }
                cmd.large_icon = cmd.small_icon = dir + "/KMK/FG/kt_spot.png"
                  MF_ENABLED
                cmd_array.push(cmd)
                cmd = UI::Command.new(item_text) { FGSystem.insert_50m60d }
                cmd.large_icon = cmd.small_icon = dir + "/KMK/FG/kt_scene.png"
                  MF_ENABLED
                cmd_array.push(cmd)
                tb  = UI::Toolbar.new(menu_text)
                  tb.add_item(i)
                  submenu.add_item(i)
              end # unless loaded
              end # module toplevel KMK`
                Dan Rathbun
                The folder should begin with "KMK_", so would be "KMK_FG"
                The extension registration script in the "Plugins" folder would be "KMK_FG.rb"
                See the API page for SketchupExtension class.
                Please use [ code ] [ /code ] blocks around your code like I did.
                And properly indent code.
                  kmk111890
                  Ok, Thanks, Dan
                  I will be able to fix it by myself ๐Ÿ˜„)
                  Thank you!!
