    Help requested for checking all nested instances
    11 Posts 2 Posters 1.8k Views 2 Watching
    • sdmitchS
      sdmitch
      Model definitions list with groups and images removed
      mod = Sketchup.active_model
      cds = mod.definitions.reject{|cd|cd.group?||cd.image?}
      Select all component instances
      cds.each{|cd| cd.instances.each{|ci|sel.add ci}}
      Array with all the components that have no nested components.
      noembed=[];
      cds.each{|cd|
       if cd.instances[0]
        embed=cd.entities.grep(Sketchup;;ComponentInstance)
        noembed << cd unless embed[0]
      http://sdmitch.blogspot.com/
      • B
        Bobvandevoort
        noembed=[];
        > cds.each{|cd|
        >  if cd.instances[0]
        >  end
        Hey man Thank you very much πŸ˜„
        However I have 2 questions, the sel.add in the 2nd code block seems to be wrong or refer to something else, can somebody check that please?
        Also what does the << operator do in this case?
        • sdmitchS
          sdmitch
          sel = mod.selection
          noembed=[];
          > > cds.each{|cd|
          > >  if cd.instances[0]
          > >  end
          Sorry. I forgot to define sel, sel = mod.selection.
          • B
            Bobvandevoort
            Ok yeah already thought it was something like that πŸ˜„
            anyway this is really helpful but for some reason when I do the following I get the wrong transformations
            noembed=[];
            cds.each{|cd|
             if cd.instances[0]
              noembed << cd.instances unless embed[0]  #### storing the instances as I need those
            noembed.flatten! # making the array workable
            • sdmitchS
              sdmitch
              noembed=[];
              > cds.each{|cd|
              >  if cd.instances[0]
              >  end
              Please define "wrong".
              noembed will contain component instances that do not contain other component instances even though they are embedded themselves. In that case you might want the transformation of the parent as well.
              If you only want the top level components instances without embedded instances then
              noembed.each{|ci|
               next unless ci.parent==mod
               puts ci.definition.name,ci.transformation.to_a;
               sel.add ci
              • B
                Bobvandevoort
                Ahhhh
                of course that's what I forgot about.
                I want the components to have their original position in the skecthup model, so that means they probably need to be transformed by their own and all their parents transformations.
                • B
                  Bobvandevoort
                  Would this work to get an array with all components of the level (aka no other nested components) that are in the same position as in the model?
                  		noembed=[];
                  		cds.each{|cd|
                  			if cd.instances[0]
                  				trans_matrix=[]
                  				if not embed[0]
                  						trans_matrix << ci.transformation;
                  					trans_matrix.each{|tr|
                  					cd.instances.transform! tr}
                  				end				#### does this give the right transformation
                  • sdmitchS
                    sdmitch
                    		noembed=[];
                    > 		cds.each{|cd|
                    > 			if cd.instances[0]
                    > 				trans_matrix=[]
                    > 				if not embed[0]
                    > 			end
                    I think it would have to be
                    trans_matrix.each_with_index{|tr,i|
                     cd.instances[i].transform! tr}
                    but that doesn't make much sense as that would only "double" the instances transformation and not all instance transformation might have been saved.
                    Maybe
                     noembed << ci
                    is what you were thinking?
                    • B
                      Bobvandevoort
                      Ah I'll try to be a bit more specific.
                      Let's say I have a model with 3 components, comp1, comp2 and comp3.
                      comp1 has comp2 inside and comp3 is inside of comp2.
                      This then means (if I am correct) that comp1 has a transformation, called trans1, comp2 has one called trans2 and comp3 has one called trans3.
                      If I take comp3 and place it in the model with its own transformation, trans3, it will not be places at its original position in the model. To achieve that it needs to have its transformation multiplied by trans2 and trans1.
                      So now I want to create a matrix "noembed" that only has components that have no other components nested inside them (like comp3 here). However these components should still retain there original location/position in the model meaning their own transformation should be multiplied by all their parent's transformations.
                      In which case this code seem to do the trick
                       noembed << ci
                      • sdmitchS
                        sdmitch
                        >  noembed << ci
                        You are correct that the transformation of comp3 not embedded will be the product of its' and the components instances transformations above it. The code above only would only save comp3's transformtion if it is at the model level.
                        It would be great if you could start at the instance and work up to the top but .parent returns a component definition which doesn't have a transformation associated with it. So you have to start at the top and drill down.
                        This code does that for two levels. Adds a comp3 at model level and erases the instance that it replaces.
                        ent = mod.active_entities
                        sel = mod.selection
                        rmv = []
                        ci0 = ent.grep(Sketchup;;ComponentInstance);#parent is mod
                        ci0.each{|c0|
                         next if c0.definition.name=="comp3"
                         tr0 = c0.transformation
                         ci1 = c0.definition.entities.grep(Sketchup;;ComponentInstance);#parent is definition
                         ci1.each{|c1|
                          tr1 = c1.transformation
                          if c1.definition.name=="comp3"
                           tr = tr0*tr1
                           ent.add_instance(c1.definition,tr)
                           rmv << c1; break
                          else
                           ci2 = c1.definition.entities.grep(Sketchup;;ComponentInstance);#parent is definition
                           ci2.each{|c2|
                            tr2 =c2.transformation
                            if c2.definition.name=="comp3"
                             tr = tr0*tr1*tr2
                             ent.add_instance(c2.definition,tr)
                             rmv << c2; break
                        rmv.each{|ci| ci.erase! if ci.valid?}
