    WebDialog parameters passed to callback cause .to_l error
    29 Posts 7 Posters 2.2k Views 7 Watching
      Jim
      How? Are you passing it as a single string?
      What I have done in the past is split values on the JavaScript side, trim leading and trailing whitespace, then join the values together using '|' character. Commas do not make good value separators because some languages use commas where we would use a decimal point in a number. Then pass the string to Ruby and split the values on the '|'.
      • sdmitchS Offline
        sdmitch
        Yes, as a single string. It's no big thing, I just thought it was curious.
        def webdialogtest
        	dlg = UI;;WebDialog.new("DialogTest", false,"DialogTest", 600, 150, 150, 150, true);
        	html = <<-HTML
        	<html>
        		<body>
        			<form action="skp;CallBack@">
        				<input name="pt1" type="text" style="width; 60px" value="" />
        				<input type="submit" value="submit">
        			</form>
        		</body>
        	</html>
        	HTML
        	dlg.set_html html
        	dlg.show
        	dlg.add_action_callback("CallBack") {|dialog, params|
        		puts "You called CallBack with; " + params.to_s
        		var,val = params.split("=")
        		x,y,z=val.split(",")
        		pt=Geom;;Point3d.new(x.to_l,y.to_l,z.to_l)
        		puts pt
        webdialogtest
        http://sdmitch.blogspot.com/
          Jim
          It is curious, and there is a lot going on behind the scenes. This document explains some of what is going on.
          You are relying on the WebDialog (and HTML specifications) to put together your form data. The form data is sent to the Ruby script as one string. There is a limit to the length the string may be. The browser replaces spaces with + signs and and possibly other substitutions. Form data is appended to the string in order they appear in the form with a & and a name/value pair separated by =.
          The problems start if you need to pass any of the symbols +, space, &, or = from the web dialog form to your Ruby script. You will find the form data difficult if not impossible to parse on the Ruby side. Here is a contrived example:
          Because of these limitations, most folks have adopted some alternative method of data serialization to encode the form data such as JSON or Base 64 encoding, all of which require some use of JavaScript to process the form data prior to sending it to the Ruby script.
            Jim
            @jolran said:
            How bout .to_f.to_l ?
            Careful..
            "1".to_l ==> 1.000000cm
            "1".to_f.to_l ==> 2.540000cm
            • jolranJ Offline
              jolran
              Yes, that is a side effect. If one would take that approach...
              It may be worth to mention "1.0".to_l doesent work either..
              I think it's debatable using forms at all..
              Passing onclick events to functions gives more options parsing the strings before sending them to Ruby..
                driven
                @jim said:
                ...Commas do not make good value separators because some languages use commas where we would use a decimal point in a number...
                can something like this be used to find the digit separator
                      [1.1].length == 2 ? sep = "." ; sep = ","
                      x,y,z = val.split(sep)
                I also found if you use to_f to clean any non digit's up on the ruby side, you break to_l
                i.e my input of 1 will become 25.4mm...
                  driven
                  "1.0".to_l
                  => 1.0mm
                  "1.0".to_f.to_l
                  =>25.4mm
                  I missed a couple of post...
                  • jolranJ Offline
                    jolran
                    Ah yeah, Jim said that already.. I only looked at the code 😳
                    puts "1.0".to_l still don't work for me.
                    Error: #<ArgumentError: (eval):258:in `to_l': Cannot convert "1.0" to Length>
                      driven
                      @jolran
                      are you still on v8...
                      • jolranJ Offline
                        jolran
                        Yes John. Still on 8. I havent had time to test the new good stuff..
                        Btw .to_s.gsub(".", ",").to_l worked for me in the node editor. But I can't remember if I did an eval on a hash_String before running that..
                        I havent touched the JS for a while...
                        Now seeing this I wonder if I got it all wrong, it seemed to work properly 😕
                        edit: puts "1.0".to_l don't work(for me) on 2014 either. But it never has so I'm suprised you made it work. Maybe because your on Mac ?
                        Oh yeah and even how ugly it may look this works: eval("+1.0").to_s.gsub(".", ",").to_l
                        Then again I believe TS is not interested in hacks..
                          Jim
                          Really? Does "1,0".to_l work?
                          • jolranJ Offline
                            jolran
                            Yes.
                              Jim
                              A begin..rescue clause can be used to test this. For a one-off:
                              len = begin
                                "1,2".to_l
                              rescue
                                "1.2".to_l
                              p len
                              But obviously it would be better to write a method to handle this for more cases.
                              • jolranJ Offline
                                jolran
                                heh 😄 yeah that works to.
                                Don't know if it's prettier than a gsub, but if it works..
                                Does the code pass through transparently if no errors, or does this add overhead?
                                It might be interesting to do a speed comparing against gsub variant.
                                Yeah, but sometimes one run into corners where direct evaluation is necissary.
                                Like get_element_value at some odd place where not possible to go through normal routine.
                                • jiminy-billy-bobJ Offline
                                  jiminy-billy-bob
                                  I use this :
                                  <span class="syntaxdefault"><br />def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">decimal_separator<br />        </span><span class="syntaxstring">'1.0'</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br />        return </span><span class="syntaxstring">'.'<br /></span><span class="syntaxdefault">    rescue ArgumentError<br />        return </span><span class="syntaxstring">','<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#def<br /><br /></span><span class="syntaxdefault">def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return str</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(/\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">+/,</span><span class="syntaxstring">''</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(/(\.|,)/,</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">decimal_separator</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_l<br />end</span><span class="syntaxcomment">#def<br />&nbsp;</span><span class="syntaxdefault"></span>
                                  This allows me to handle pretty much anything the users enters.
                                    driven
                                    isn't it faster to test for true
                                    def self.decimal_separator
                                        [1.1].length ==  2  ?  ',' | '.'
                                    end#def
                                    • jolranJ Offline
                                      jolran
                                      Guys 👍
                                      This place is a great source of information.
                                        jiminy-billy-bob
                                        Maybe 😄 It's widely fast enough for my use (Parsing one string at a time entered by the user)
                                        • tt_suT Offline
                                          tt_su
                                          > end#def
                                          You never know for sure until you profile the code. And in Ruby you get many surprises. That being said - unless you have a noticeable performance issue there is little need to pre-optimize.
                                            Jim
                                            > end#def
                                            Maybe I do not know off-hand. This is code you would run at most one time in a plugin to determine which separator to use so it isn't terribly important to optimize.
                                            The code that actually performs the conversion may need optimized especially if there are many conversions to do.
