    Draw face from webdialog
    2 Posts 2 Posters 357 Views 2 Watching
      davesexcel
      I have HTML code to create a webdialog form.
      How do I Make a face with these points and Use the pushpull selection and create the group name---when I click the button?
      require 'Sketchup'
      def show_dialog
      dlg = UI;;WebDialog.new("DialogTest", false,
      "DialogTest", 600, 150, 150, 150, true);
      html = <<-HTML
      <form>
      <body>
      <div class="style1" style="width; 511px; height; 70px">
      				<label id="Label1">Name 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
      				pt1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; pt2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
      				pt3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
      				pt4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
      				Thick<br>
      				</label>
      				<input name="Group1" type="text" value="Group1" style="width; 62px" />&nbsp;&nbsp;&nbsp;&nbsp;
      				<input name="pt1" type="text" class="style2" style="width; 46px" value="(0,0,0)" />&nbsp;
      				<input name="pt2" type="text" style="width; 54px; height; 22px" value="(0,10,0)" />&nbsp;
      				<input name="pt3" type="text" style="width; 63px" value="(0,10,10)">&nbsp;
      				<input name="pt4" type="text" style="width; 58px" value="(0,10,0)">&nbsp;
      				<select name="pushpull" style="width; 65px">
      				<option></option>
      				<option selected="">1</option>
      				<option>2</option>
      				<option>3</option>
      				</select>&nbsp; <input name="OK" type="button" value="button"></div>
      <p>&nbsp;</p>
      </body>
      </form>
      HTML
      dlg.set_html html
      dlg.add_action_callback("ruby_messagebox") {|dialog, params|
      UI.messagebox("You called ruby_messagebox with; " + params.to_s)
      dlg.show
      show_dialog
      • sdmitchS Offline
        sdmitch
        add an action to the form
        <form action="skp:ruby_messagebox@">
        change button type to "submit"
        In the callback
        tokens=params[1..-1].split("&");
        tokens.each{|t|
        var,val = t.split("=");
        case var
        when "pt1" then pt1=Geom::Point3d.new(val)
        http://sdmitch.blogspot.com/
