    Yosemite filter code...
    6 Posts 2 Posters 583 Views 2 Watching
      driven
      in case it's of use to anyone else, this is the simplest filter I found...
       if  %x(sw_vers -productVersion).split('.')[1].to_i > 9
          puts 'we have Yosemite, good to go'
        else
          UI.messagebox( "This code works only for Yosemite " )
      EDIT: added a needed split...
      • Dan RathbunD Offline
        Dan Rathbun
        For Windows:
        v = %x[ver].split.last.to_f
        5.1 = XP
        6.0 = Vista
        6.1 = Win7
        6.2 = Win8
        I'm not here much anymore.
          driven
          hi dan,
          what's the windows cmd for merging two folders?
          on the mac I'm using
           def ditto(source, target)
             %x(ditto "#{source}" "#{target}")
          404 Not Found
          (osxdaily.com)
            driven
            cheers dan,
            I've got a migration plugin I keep updating on each release, and with Ruby 2 it's became so simple I just wondered if PC's could use it as well...
            I only bother with bring the last version forward to the 'approved' folders...
            can I PM you it, to have a look?
              Dan Rathbun
              xcopy - but on windows a blank cmd window flashes (annoyingly) up on the screen.
              I had nothing but issues trying to use xcopy from Ruby., so I gave up.
              I prefer to use WIN32OLE and Windows Scripting Host's FileSystemObject.CopyFolder()
              ➡ [MSDN: FileSystemObject.CopyFolder()](http://msdn.microsoft.com/en-us/library/xbfwysex(v)
              require("win32ole")
              fso = WIN32OLE.new("Scripting.FileSystemObject")
              fso.CopyFolder( "#{source}/*", "#{target}" )
              .. because for older Ruby 1.8 on Win there is only 1 binary ("win32ole.so") to pack along with your plugin.
              Or for Ruby 2.0+ and more Unix-like, cross-platform, use the Ruby Standard library:
              ➡ Ruby Doc: FileUtils::cp_r
              require("etc") # binary
              require("FileUtils") # rb
              FileUtils;;cp_r( "#{source}/.", "#{target}" )
              which probably calls something like this on OSX:
              out = %x(cp -R -P -p "#{source}/","#{target}/")
              ➡ Apple Dev: cp man page
              EDIT: The snippets above should really be wrapped in begin .. rescue blocks since they do File IO. Notify user of progress, errors, etc.
                Dan Rathbun
                Sure, John.
