    Problems defining a method
    4 Posts 3 Posters 609 Views 3 Watching
    • Y Offline
      yiannicivil
      I am encountering an mysterious issue while defining a method.
      Code goes as follows:
      mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      u = [1,0,0]
      apoint = [1,0,0]
      face1 = sel[0]
      def classifiy(u, point1, face1)
         # σημείο προβολής
         pt = Geom;;Point3d.new pt
         result = faces_array[0].classify_point(pt)
         ent.add_cpoint pt
         if result == Sketchup;;Face;;PointOutside
            UI.messagebox(pt.to_s + ' is outside the face')
         elsif result == Sketchup;;Face;;PointInside
            UI.messagebox(pt.to_s + ' is inside the face')
         elsif result == Sketchup;;Face;;PointOnVertex
            UI.messagebox(pt.to_s + ' is on a vertex')
         elsif result == Sketchup;;Face;;PointOnEdge
            UI.messagebox(pt.to_s + ' is on an edge of the face')
         elsif result == Sketchup;;Face;;PointNotOnPlane
            UI.messagebox(pt.to_s + ' is not on the same plane as the face')
         result
      classify (u, apoint, face1)
      I get an error:
      Error: #<SyntaxError: C:/my_path.../3.rb:27: syntax error, unexpected ',', expecting ')'
      classify (u, point, face1)
      C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/test.rb:27: syntax error, unexpected ')', expecting '='
      <main>:in load' <main>:in <main>'
      -e:1:in `eval'
      nil
      Why is this happening? Other methods with multiple arguments work just fine..
      I cant figure this out on my own.. Can anyone help?
        driven
        hi you have a spelling typo...
        and a couple of things outside of scope.
        once the typo is fixed, the errors show the scope issues
        @ent = mod.entities # All entities in model
        u = [1,0,0]
        apoint = [1,0,0]
        face1 = sel[0]
           # σημείο προβολής
           pt = Geom;;Point3d.new #pt
           result = face1.classify_point(pt)
           @ent.add_cpoint pt
           #result
        classifiy(u, apoint, face1)
        • Y Offline
          yiannicivil
          Thank you John. I actually worked it out after trying really hard to see whats going wrong.
          I guess you can see I am a starter in ruby scripting, though it is really fulfilling to see my code actually work!
          • tt_suT Offline
            tt_su
            Your error message pointed to the last line in your code:
            I suspect it was the space between the method name and parentheses. Especially when you encounter syntax error it's good to go over your code and make sure the code style is consistent. Checking that there are no spaces between parentheses in method calls and making sure you have parentheses around all arguments etc.
