    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 334.8k Views 53 Watching
      Anton_S
      This message pops up because you didn't save animation or doing it wrong.
      To export replay animation, you must follow these steps:
      • Enable recording.
      • Press play simulation.
      • Run simulation for desired time, and press reset. It will ask you to save animation, press YES.
      • Then, you may export animation...
      Oh wait this error pops up from the other plugin... Maybe I changed storage locations. I will see what I did there.
      Edit: I see what I did there. Storage locations are same, but storage types are different. I changed them from array to hash. I will upload a fix tomorrow.
        Anton_S
        I never knew other plugins use SketchyReplay and thought making changes will not break anything, but gosh I was wrong. This is the same issue with Werners post. The fix is easy. I will upload it tomorrow.
          Have you some info with the use of SketchyPhysics and LightUP ?
          Seems that works with the previous versions of SketchyPhysics but not for this one ?
          Maybe Adam will confirm or not this ๐Ÿค“
            mptak
            Anton you are stupendous!
              Always funny for makes some random landscape of elements but...
              How export the resultant position of the animation ? The "Pause" position !
              In the past "Save as" was sufficient!
              Now "Save as" save the "Start position" ! ๐Ÿ˜ฎ
              Not practical for make cool image! ๐Ÿ˜‰
              By Pierreaudoin
              http://sketchucation.com/forums/download/file.php?id=94758&t=1
                Anton_S
                By Pierreaudoin
                ugh what?
                If you don't want to save camera you can simply set 'Animate Camera' to 'No' (when exporting animation).
                • cottyC
                  cotty
                  Maybe you are searching for this answer?
                  http://sketchucation.com/forums/viewtopic.php?f=61&t=58901
                  my SketchUp gallery
                    1 Enable recording
                    2 Start simulation
                    3 Reset simulation at desired time. It will ask you to save animation. Press YES.
                    4 Then use the replay tool to get yourself to the desired frame.
                    After you do so, press the replay button once again to pause and the objects will be left in their new positions.
                    must add 4 : first rewind with the replay tool button!
                    Yes thx that is that! โ˜€
                    At this end I save as V6 for example for using plugins not adapted at the 2014! ๐Ÿค“
                      It's ok for LightUp during the "Sketchy Replay" animation ! ๐Ÿ˜Ž ๐Ÿ‘
                      Not during the Toggle Play "Sketchy Physics" but no problem as the "Replay" works fine! ๐Ÿ˜‰
                        Anton_S
                        Great! Lets wait for a response from Werner, and I'll make it an official release if everything goes well.
                          Anton_S
                          BTW, thanks for testing Pilou, you rock!
                          • W
                            Werner_Hundt
                            Thanks for your swift reply, Anton. Unfortunately, the error message still pops up.
                              Anton_S
                              Okay, I downloaded Skindigo, and can reproduce the effect. I looked into source and found some inconsistency. I will upload a fix in few minutes.
                                Anton_S
                                Okay, I reverted some replay changes. Please test with LightUp and Skindigo. Tell me how it goes.
                                Edit: Link removed. Download from top.
                                  Anton_S
                                  Okay, I fixed it. Although current version of Indigo has a little bug.
                                  Keep in mind SkIndigo 3.6.28.3 has a little bug. Please follow these steps to fix it:
                                  1. Open Plugins/skindigo/AnimationExport.rb.
                                  2. Scroll down to line 369 and replace mb.build_active_mesh(ents) with mb.build_active_mesh(ents, {})
                                  3. Save file and you're good to go.
                                    I reported an error to SkIndigo support.
                                  Download latest version from top.
                                  I also finished a little SP script reference doc : http://sketchyphysics.wikia.com/wiki/Script_Overview
                                  • cottyC
                                    cotty
                                    I've searched for that line in the current version 3.8.9.1 but the line (406) is marked as a comment...
                                    my SketchUp gallery
                                      Anton_S
                                      I was speaking of 3.6.28.3 (as it shows up on SkIndigo website), but downloading the latest version 3.8.9.1 I find there a different bug, even if I try exporting from old SP versions. These guys need to test things before they upload it...
                                      I will send an error message to them for this version as well. Yet, I can't fix it, as there are too much errors. Use version 3.6.28.3 with the fix I provided in the first post. Otherwise, you'll have to wait till they fix it.
                                      • AdamBA
                                        AdamB
                                        As Pilou says, the playback works, but running the Physics while in LightUp no longer works which is a pity.
                                        Its not that LU is not picking up the changes in transforms - its that SP appears to terminate TourTool now - whereas before it didn't touch the current selected Tool.
                                        Does that ring any bells in the changes you've made recently?
                                        Adam
                                        • W
                                          Werner_Hundt
                                          You're a genius, Anton! You should consider collaborating with the guys from Indigo/Skindigo ๐Ÿ˜„
                                            Anton_S
                                            @Adam All SketchyPhysics3 versions used a select_tool when simulation start, which terminates all other running tools. If you don't think so, you can download SP3.2 (the official release) on SU8 for instance and see it yourself. Start lightup and press physics toggle play button. LightUp will reset...
                                            Use SP Replay as it was made for such purpose, I think. I don't know why you were assuming SP toggle play button worked with LightUp as it never worked with any versions of SP3. Maybe because SP1 or SP2 worked that way, I don't know.
                                            Edit: Mayby I'm starting LightUp wrong, or I have to do it the other way around. If so, please explain how.
                                            • 11
                                            • 1 / 11
