    Put forward drawings openGL
    14 Posts 4 Posters 1.1k Views 4 Watching
      Anton_S
      Nothing's complicated:
      https://googledrive.com/host/0B3qg8f4WrNdHWktZLXN5T2d6Tms/highlight_picked_body.gif
      Place in Plugins folder
      Access: (Menu) Plugins → Highlight Tool
      However, I can't make it work while the other tool is active.
      • sdmitchS Offline
        sdmitch
        X-ray mode?
        http://sdmitch.blogspot.com/
        • jolranJ Offline
          jolran
          Nice Anton_S! Useful code.
          Can't one just delegate to the other class/tool ?
          Or are you talking about some other issue..
          Initializing an instance of the other toolclass in current tool and delegate the useful methods ?
          Or is that bad practice or do there exist a better way ?
          I'm interested in doing this properly..
            Anton_S
            If your thinking of including this in your tool, then yes, this is absolutely possible. I was making an argument about having this tool active while the other tools are active too. I'm thinking dacastror wants this to be active while the other tool is active, but I'm not sure yet. I mean the select tool, push pull tool, scale tool, rotate tool - How to incorporate this tool into them or how to keep this tool active while the other tools are active too?
            • jolranJ Offline
              jolran
              Ahh, ok. Now I see what you meant. Good point.
              I don't think one can have costume tools active alongside Sketchup native tools(They are not written in Ruby?)
              I havent seen that anyway. Would save a lot of effort if possible..
                dacastror
                thanks for answering, I do not mean to have two tools running simultaneously, what I want to do is create a clone of the scale tool to add additional features, I do not understand is how to draw a cube in front of sketchup instances, or draw a cube in 2d consistent with the perspective
                • jolranJ Offline
                  jolran
                  We use the draw2d methods because they DO draw in front of Sketchup Geometry.
                  (I'm sure someone is going to pitch in and tidy this info 😄 )
                  The view.screen_coords method converts 3d(x,y,z) positions to screen X and Y positions, (valid as 2nd argument in the draw2d methods).
                  For an easy example. to convert a boundingbox cornerpoints to view screen points (untested!):
                  # Somewhere in your class...
                  bb = @group.bounds # could be any element responding to Bounds.
                  @corners_to_screen_position = (0..7).collect{|i| view.screen_coords( bb.corner(i) ) }
                  # in your toolclass draw-method
                  view.draw2d( GL_POINTS, @corners_to_screen_position )
                  You could use any GL constant for drawing other types of geometry, but this should give you the idea.
                    dacastror
                    thank you very much Jolran, view.screen_coords is very useful,
                    Initially I did this:
                    class DibujaCubo3d
                      def activate
                        @size = 60
                        @tr = Geom;;Transformation.new([20,10,30])
                      def transformar(pts,axis_num)
                        pts = pts.map{|p| [p.z,p.x,p.y]} if axis_num == 0
                        pts = pts.map{|p| [p.y,p.z,p.x]} if axis_num == 1
                        pts = pts.map{|p| p.transform! @tr}
                      def draw_square(view, axis_num, size, alto)
                         pts = [[0,0,alto],[size,0,alto],[size,size,alto],[0,size,alto]]
                         pts = transformar(pts,axis_num)
                         view.drawing_color = [0,0,0]
                         view.draw GL_LINES, pts
                         view.drawing_color = [0,255,0]
                         view.draw GL_QUADS, pts
                      def draw(view)
                        3.times{|i| draw_square(view, i, @size, 0)}
                        3.times{|i| draw_square(view, i, @size, @size)}
                    Sketchup.active_model.select_tool DibujaCubo3d.new
                    and this is the best that I can get for now
                    class DibujaCubo
                      def activate
                        @size = 60
                      def transformar(view,pts,axis_num)
                        pts = pts.map{|p| view.screen_coords(p.transform!(@tr))}
                      def points_square(view, axis_num, size, alto)
                        pts = transformar(view,pts,axis_num)
                      def draw_shapes(view, tipe, size, color)
                        view.drawing_color = color
                        3.times{|i| view.draw2d tipe, points_square(view, i, size, 0)}
                        3.times{|i| view.draw2d tipe, points_square(view, i, size, @size)}
                      def draw(view)
                        draw_shapes(view, GL_QUADS, @size, [0,255,0])
                        draw_shapes(view, GL_LINES, @size, [0,0,0])
                    Sketchup.active_model.select_tool DibujaCubo.new
                    always shown ahead of all geometry!
                    • jolranJ Offline
                      jolran
                      It's working 😄
                        dacastror
                        Anton_S your code is very interesting (highlight_picked_body.rb), I have never used Start and stop operation inside a custom tool, I like the result, I am studying this code
