    Packed Pixels - An extra monitor for your laptop
    9 Posts 4 Posters 2.7k Views 4 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Packed Pixels - An extra monitor for your laptop!
      The desktop experience on the move
      Packed Pixels allows you to have a multi-monitor setup for your laptop that:
      Fits in your laptop bag
      Needs no additional plugin power supply
      Is quick to setup
      Needs no drivers and works with Windows, OS X and Linux
      Its a clever idea and one that I hope gets traction as it would be great to have some extra screen real-estate when working on my MBP with graphics.
      Check Packed Pixels out here,
      https://www.kickstarter.com/projects/753230753/packed-pixels-an-extra-monitor-for-your-laptop-0
        Mike Lucey
        ...... as you may have guessed, I pledged for a Packed Pixels monitor.
        I've been in touch with the developer, Matt Relf, and he tells me that he is a big fan of SketchUcation and that the first few versions of Packed Pixels were designed on SketchUp before he had to make the switch to a IGES compatible package for injection molding but he still uses SketchUp for all his other CNC and 3D print projects.
        I hope to get some of the initial design work done on SketchUp to see how it worked out.
          It's an Ipad cousin ? πŸ˜‰
            Mike Lucey
            It will use the same screen as the iPad, 2048x1536 9.7".
            I occasionally use iPad as a second screen for the 15" MBP via WiFi using Air Display but its a bit buggy and laggy.
            I think when you consider that the cost of an iPad is in the region of $520 and the Packed Pixel is available for $235, its a pretty good deal for anyone that needs extra screen real estate. Even two Packed Pixels cost less than the price of an iPad πŸ‘
            • olisheaO Offline
              olishea
              looks great!
              oli
                Mike Lucey
                Yes it does Oli.
                The first attempt on KickStarter failed but the guys at Dovetail Technology have relauched today and as I write they have achieved 20% of their pledge target and it looks like they will surpass the Β£60K target by the end of the campaign.
                Here is the new campaign link, https://www.kickstarter.com/projects/753230753/packed-pixels-an-extra-monitor-for-your-laptop-0
                Mike
                  PackedPixels
                  Hi Sketchucation,
                  I intend to do a more detailed post on here when I can about how I used Sketchup for the initial designs for Packed Pixels, but as I'm sure you'll understand my focus at the moment is on our Kickstart campaign.
                  In brief though my history with 3D goes way back to cutting my teeth on POV Ray (anyone remember that?) and even writing my own basic 3D renderer on an Acorn Archimedes. I later did some professional work on 3D Studio (the DOS based pre-Max version) doing various bits and bobs including modelling a full leisure centre. The switch to 3DS Max was very welcome when that was released!
                  I don't remember now when I first discovered Sketchup but it was many years ago now. I do remember instantly falling in love with it. The fact it seemed to read my mind as to which axis I wanted a line to be drawn in was just awesome.
                  Over the years I have used Sketchup for all sorts of things. I have the property I'm renovating fully modelled on it with very precise measurements. This has been great for planning out the fine detail of each room we get to so we know exactly what we are doing.
                  I have also designed various pieces of furniture on Sketchup which I have then made. This then led onto a major project I did a few years ago where I designed my own CNC router from scratch on Sketchup, right down to nuts and bolts level. This I then built with the designs for custom parts taken straight out of Sketchup and sent for manufacture.
                  The combination of Sketchup and my own large format CNC machine (it takes 8'x'4 sheet material) has been fantastic. All sorts of things have been made; 3D carved door signs and headboards, curvaceous desk, coffee tables, etc. At one point I was even making weaving looms for my mum and her friends.
                  About 2 years ago we started development of Packed Pixels after many years of being frustrated in our professional lives with not having enough screen real-estate when out on client sites. We looked around at the existing portable monitor solutions and found them all to have drawbacks and so set about designing our own.
                  My experience with Sketchup made it the natural choice of package and the initial designs came together. We then reached a point where we needed to make a physical prototype. I personally had always fancied a 3D printer but given we were so busy it seemed that another gadget to learn was a step too far so we sent out the designs to three 3D print houses for quotes. When the quotes came back in we quickly realised that it would only take between 2 and 3 prototype runs to make buying our own 3D printer the cheaper option. So after looking at the options we went for for second hand (hardly used) BFB 3D Touch. At the time Makerbot only had the single model and it didn't have a big enough print area for Packed Pixels whereas the 3D Touch has a pretty huge print area.
                  As with the CNC machine the combination of Sketchup and a 3D printer has been great. Not only have we been through several iterations of design with Packed Pixels we've used it to produce all sorts of natty little solutions to problems around the office and home.
                  Once we got Packed Pixels to a point where we were happy with the case design we started talking to injection moulding companies and we quickly found that we had reached Sketchup's limits. Because Sketchup is a polygon based system it doesn't do curves and instead splits curves up into small lines. You can get away with this in 3D printing because the resolution of 3D printers at the moment is worse than Sketchup's resolution. The same can't be said for the high precision CNC machines which cut the injection moulding tooling. There is also the issue that the software used by tooling manufacturers expect IGES files. It was at this point we had to move Packed Pixels away from Sketchup and we moved to Autodesk's Fusion 360 product. This was primarily on cost grounds as it was in Beta at the time and therefore free! It is still very much a product in active development and so there have been frustrating crashes but these happen less and less and the new features they keep adding are great. BUT, it still lakes the utter ease of Sketchup.
                  The story of Sketchup and Packed Pixels doesn't end there though as we reached a point where we needed renderings of Packed Pixels and we found Fusion 360's built in render tools had some limitations we could work around easily and so we exported our designs back to Sketchup and played around with the various rendering plugins. In the end we found ArtVPS' excellent Shaderlight product to be the best balance of power and ease of use. You can see the results at http://www.packedpixels.com
                  If you like what you see please take a look at our Kickstarter campaign here https://www.kickstarter.com/projects/753230753/packed-pixels-an-extra-monitor-for-your-laptop-0
                  I run two of our prototypes and while doing the renderings it was very useful to have the Shaderlight preview on the left Packed Pixels, the main Sketchup window on my laptop screen and all my Sketchup tool bars on the right Packed Pixels.
                  Cheers,
                  Matt Relf
                    Mike Lucey
                    Welcome Matt and thanks for the informative background story on Packed Pixel, most interesting πŸ‘
                    Mike
                      Mike Lucey
                      Packed Pixel has reached 75% of the target in a week.
                      Some renders, noted the third down is a SketchUp set-up πŸ‘
                      Here is an update link,
                      https://www.kickstarter.com/projects/753230753/packed-pixels-an-extra-monitor-for-your-laptop-0/posts/1016558?at=BAh7CDoMcG9zdF9pZGkD7oIPSSIIdWlkBjoGRVRpA8P8DEkiC2V4cGlyeQY7BlRJIhgyMDE0LTExLTEzIDIxOjAyOjIwBjsGVA%3D%3D--7f9d5b04a512cc1f01580a9ae40c801c106aa922%26amp;ref=backer_project_update
