    [solved] a small syntax problem
    4 Posts 2 Posters 437 Views 2 Watching
    • artmusicstudioA
      artmusicstudio
      hello,
      when i run this code (with 10 faces and NO GROUPS in the selection)
      @selection.each { |@entity|
      	if @entity.is_a?(Sketchup;;Face)
      		  puts "face"
               elsif @entity.is_a?(Sketchup;;Group)
      		  puts "group"
      the "face" is printed 10 times and
      the "group" is printed 10 timesin the console.
      what is wrong with my elsif condition?
      thanx a lot
      stan
      • jolranJ
        jolran
        Dont use an instance variable in the iterator 😲
        Should be
        @selection.each { |entity|
        Otherwise I'm totally misinformed.
        The values get stored in the instance variables during the session wheras the
        entity variable gets executed in the iterators scope only, if that makes sense what I say..
        • artmusicstudioA
          artmusicstudio
          hello jorlan,
          thanx for the tip.
          i corrected it, so the code is clearer (i have to trasport this value to another method, so i assigned an independent variable to ,entity'.)
          stan
          • jolranJ
            jolran
            No problem, glad to help if the tip worked. πŸ˜„
