    [Sketchup C API]Howto merge models oftwo .skp files into one
    5 Posts 3 Posters 838 Views 3 Watching
      rahulnejanawar
      Assumption: My models contain only ComponentInstances.
      My Approach:
      1. Get the models of each of the file, say m1,m2 (using SUModelCreateFromFile).
      2. Get entities of m1 and m2, say e1,e2 (using SUModelGetEntities).
      3. Get ComponentInstances from e2 (using SUEntitiesGetInstances).
      4. In a loop add each of the ComponentInstance of e2 into e1 (using SUEntitiesAddInstance).
      5. Write the model m1(with entities e1) to a new file.
        //The new file contains the ComponentInstances of m1,m2.
      Where I am stuck?
      In the below code.
      On a high level the below program does three things
      1. It gets the Model from file.
      2. From Model it gets Entities.
      3. From Entitites it gets ComponentInstances. Here it fails.
      #include <slapi/slapi.h>
      #include <slapi/geometry.h>
      #include <slapi/initialize.h>
      #include <slapi/model/model.h>
      #include <slapi/model/entities.h>
      #include <slapi/model/face.h>
      #include <slapi/model/edge.h>
      #include <slapi/model/vertex.h>
      #include <vector>
      #include <iostream>
      #include <stdio.h>
      int main() {
        // Always initialize the API before using it
        SUInitialize();
        // Load the model from a file
        SUModelRef model_to_write1 = SU_INVALID;
          SUResult m1 = SUModelCreateFromFile(&model_to_write1, "model11.skp");
        if(m1 == SU_ERROR_NONE)
      	std;;cout<<"SUModelCreateFromFile SUCCESS!!!!!";
        else if(m1 == SU_ERROR_NULL_POINTER_INPUT)
          std;;cout<<"Error_Entities -- Inside 1 file are";
        else if(m1 == SU_ERROR_NULL_POINTER_OUTPUT)
          std;;cout<<"NULLPOINTER_Entities -- Inside 1 file are";
        else
      	  printf("None of the above");
       SUEntitiesRef entities1 = SU_INVALID;
       size_t* size1 = NULL;
       SUComponentInstanceRef comp1[10];
       SUResult result = SUModelGetEntities(model_to_write1, &entities1);
       if(result == SU_ERROR_NONE)
      	std;;cout<<"\n SUModelGetEntities SUCCESS !!!!!";
       if(result == SU_ERROR_INVALID_INPUT)
          std;;cout<<"Error_Entities Inside 1 file are";
       if(result == SU_ERROR_NULL_POINTER_OUTPUT)
          std;;cout<<"NULLPOINTER_Entities Inside 1 file are";
        result = SUEntitiesGetInstances(entities1,2,comp1,size1);
      	std;;cout<<"\n SUEntitiesGetInstances SUCCESS";
        else if(result == SU_ERROR_INVALID_INPUT)
          std;;cout<<"\n Error_Copy";
        else if(result == SU_ERROR_NULL_POINTER_OUTPUT)
          std;;cout<<"\n NULLPOINTER";
        // Save the in-memory model to a file
        SUModelSaveToFile(model_to_write1, "very_new_model.skp");
        SUTerminate();
        getchar();
        return 0;
      Output:
      NULLPOINTER
      Questions:
      1. In the above output I am getting NULLPOINTER(3rd line) which is the result of call SUEntitiesGetInstances(entities1,2,comp1,size1) in the above program. Why I am not able to get the ComponentInstances?
      2. Can you please review the approach which is mentioned at the beginning and let me know if is it right?
      model11.skp
      • tt_suT Offline
        tt_su
        The error is that you are passing a NULL pointer as the count argument to SUEntitiesGetInstances. You should pass a reference to an initialized value:
          size_t instanceCount = 0;
          SUEntitiesGetNumInstances(entities1, &instanceCount);
          std;;vector<SUComponentInstanceRef> instances(instanceCount);
          size_t count = 0;
          result = SUEntitiesGetInstances(entities1, instanceCount, &instances[0], &count);
        Full snippet:
        #include <vector>
        #include <iostream>
        #include <stdio.h>
        int main() {
          SUInitialize();
           std;;cout << "SUModelCreateFromFile SUCCESS!!!!!" << std;;endl;
            std;;cout << "Error_Entities -- Inside 1 file are" << std;;endl;
            std;;cout << "NULLPOINTER_Entities -- Inside 1 file are" << std;;endl;
          else
            std;;cout << "None of the above; " << m1 << std;;endl;
           std;;cout << "SUModelGetEntities SUCCESS !!!!!" << std;;endl;
            std;;cout << "Error_Entities Inside 1 file are" << std;;endl;
            std;;cout << "NULLPOINTER_Entities Inside 1 file are" << std;;endl;
          size_t faceCount = 0;
          SUEntitiesGetNumFaces(entities1, &faceCount);
          if (faceCount > 0) {
            std;;vector<SUFaceRef> faces(faceCount);
            result = SUEntitiesGetFaces(entities1, faceCount, &faces[0], &faceCount);
              std;;cout << "SUEntitiesGetFaces SUCCESS" << std;;endl;
            else
              std;;cout << "SUEntitiesGetFaces Fail!" << std;;endl;
          size_t count = 0;
           std;;cout << "SUEntitiesGetInstances SUCCESS" << std;;endl;
            std;;cout << "Error_Copy" << std;;endl;
            std;;cout << "NULLPOINTER" << std;;endl;
          SUTerminate();
          getchar();
          return 0;
        • Dan RathbunD Offline
          Dan Rathbun
          Wouldn't the Component Definitions of m2 need to be loaded into m1, and then using the transforms of the instances from m2, new instances made within m1's entities, and then a new model file written out as m3 ?
          I'm not here much anymore.
            rahulnejanawar
            Thank you Thomas. We got the whole thing working except for one small thing. We need your input for the same.
            Problem: The files m1 and m2 which we want to merge to m3 - have the "Millimeters" units. But the merged file m3 gets saved with "Inches" units. I see that there is a way to get SUModelGetUnits from the model. But no method to Set the units for the model. Is there any method (any other indirect way) - such that the new file gets saved with "Millimeters" units?
            By the way the approach for merging is below and it works for us.
            1. Get the models of each of the file, say m1,m2.
            2. Get entities of m1 and m2, say e1,e2.
            3. Get Instances from e1 and e2, say i1, i2 ( assume we have 1 instance in each model)
            4. Get Definition of i1 and i2, say d1 and d2
            5. Create new instances of d1 and d2, ni1 and ni2
            6. Create a new empty model , say new_model
            7. Get the entities of new_model, say new_entities
            8. Now add ni1 and ni2 to new_entities
            9. Save the new_model to file
            10. Release the memory
            We are yet to work on the transformations for merging
            • tt_suT Offline
              tt_su
              I'll check with the rest of the team on the unit issue.
