    How to read .skp files in ruby?
    6 Posts 3 Posters 1.0k Views 3 Watching
      rahulnejanawar
      I have written some plugins and I have some .skp files containing some models.
      I want to be able to read these files programmatically and run my plugins on those models. Is it possible?.
      I read about Sketchup C API. This is C. My plugins in ruby. So I was not sure how to use them together. Is the ability to read .skp files and get models available in ruby? Any pointers to examples?
      • tt_suT Offline
        tt_su
        You can only read the open model in Ruby. To read SketchUp models on disk you need to use the C API. We have made a Ruby C++ extension example that can be used as a boilerplate for using C_libs - like the C API:
        https://github.com/SketchUp/ruby-c-extension-examples
          rahulnejanawar
          Thank you
            pgarmyn
            A workaround is to import the model.
            The first added definition contains the loaded model, the other definitions are those of the nested components and groups.
            Your plugin can retrieve information, or modify those definitions, write them back to disk and delete the instance and definition of the loaded model.
            But there can be name-conflicts (materials, components...) beween the loaded and the main model. EG: Sketchup will rename the materials of your model if ....
            • tt_suT Offline
              tt_su
              ❓ What do you mean by that?
              The root model entities are only available from model.entities. Everything in model.definitions belongs to groups, components or images.
                pgarmyn
                When you import a model, the entities (edges, faces, groups,... ) don't go directly in model.entities. They are encapsulated in a new component....
