π¨ Skimp | 25% Off until March 30 Buy Now
[Code] encapsulate instance into group
This snippet meant to be wrapped inside your own module namespace (or in one of it's sub-namespace classes or submodules.) Please do not run it at the toplevel, except for testing.
def encapsulate( instance, into_group ) if instance.is_a?(Sketchup;;Group) itype = 'group' elsif instance.is_a?(Sketchup;;ComponentInstance) itype = 'component' else raise(TypeError,"group or component instance argument(#1) required",caller) end unless into_group.is_a?(Sketchup;;Group) || ( into_group.is_a?(Sketchup;;ComponentDefinition) && into_group.group? ) raise(TypeError,"group argument(#2) required",caller) end model = instance.model if model.active_path != nil && model.active_entities != instance.parent.entities model.close_active until model.active_path == nil || model.active_entities == instance.parent.entities end if model.active_entities != instance.parent.entities msg ="Current editing context & instance's parent context\n"<< msg<<"do not match! Cannot encapsulate #{itype} instance." puts(msg) if $VERBOSE UI.messagebox(msg) else begin ### model.start_operation("Encapsulate #{itype.capitalize}",true) # if instance.is_a?(Sketchup;;Group) definition = instance.entities.parent elsif instance.is_a?(Sketchup;;ComponentInstance) definition = instance.definition end transform = instance.transformation newbie = into_group.entities.add_instance( definition, transform ) if newbie # copy the old instance's properties; unless instance.material.nil? newbie.material = instance.material end unless instance.name.nil? || instance.name.empty? newbie.name = instance.name end unless instance.description.nil? || instance.description.empty? newbie.description = instance.description end newbie.casts_shadows= instance.casts_shadows? newbie.receives_shadows= instance.receives_shadows? newbie.hidden= instance.hidden? newbie.locked= instance.locked? newbie.layer= instance.layer unless instance.attribute_dictionaries.nil? dset = instance.attribute_dictionaries dset.each {|d1| d2 = newbie.attribute_dictionary(d1.name,true) if d1.size > 0 d1.each {|key,val| d2[key]= val } end } end # delete old instance; instance.locked= false instance.parent.entities.erase_entities(instance) end # model.commit_operation() ### rescue => e model.abort_operation() msg ="Warning... the #{itype} instance could not be copied!\n\n" msg<<"Modeling operation was aborted due to error;\n" msg<<"#{e.class.name}; '#{e.message}'" puts(msg) if $VERBOSE UI.messagebox(msg) return false else # Caution, the original instance reference is now invalid !! msg ="Success. The #{itype} instance was copied into\n" msg<<"the group, and the original instance was erased." puts(msg) if $VERBOSE UI.messagebox(msg) return newbie end end end # encapsulate()Updated (2014-03-16) to copy properties of old instance to the new one.
Updated (2014-03-17) to fix line 57,dsetwas misspelleddest.
