    SketchUp and OSX Mavericks....
    83 Posts 22 Posters 16.0k Views 22 Watching
      DidierML
      I have experienced a few bugs. I'm not entirely if they are related to Mavericks, but they seem to have appeared after the update.
      • My tool palettes ( Layers, Style, Scenes, etc ) don't "stick" together anymore. When I click on them to enlarge, they just dissociate from the others, which is pretty annoying.
      • I have experienced a few other visual bugs while using Mission Control (with the gestures) ; palettes don't come back as they should, or just slower performances.
      • mariochaM Offline
        mariocha
        @tig said:
        So to recap... πŸ˜„ πŸ˜• ...
        So anyone experiencing issues like this with remote url dialogs Mavericks-only should check that their dialog includes the allow_actions_from_host(string) AND that it has a good 'string' that is a 'domain' and not a 'url' [or a typo!]... ... πŸ˜’
        Hum... will this also correct the "Java Script disabled" problem ?
        %(#008000)[Mario C.
          Regular Polygon
          Hi Mariocha,
          I think it will. Keyframe Animation reports that error when it can't connect to the server. The web dialog that would connect is probably failing because I didn't implement the WebDialog.allow_actions_from_host method. I'll release an update as soon as I have a chance. Perhaps you could test it for me -- I don't have a computer with Mavericks.
          My SketchUp Plugins
            Make sure you pass the method a valid domain-name - NOT the http:// address...
            That 'type' error and also typos in a seeming correct domain-name etc caused difficult to track-down issues [with Mavericks only] when included in some other scripts that use that method πŸ˜’
              ayala80
              hi, i tried to import a .dwg file to sketch up and this warning appears instantly: "warning, importer not found".
              thanks.
              I'm running sketch up pro 8 on Mac osx 10.9, and the .dwg file is 2010.
                pichuco
                In my case (SU 8 PRO& Mavericks) I can't import DWG files. A dialog appears saying: Alert, importer not found. Also I noticed that the Palettes don't work as expected. Very sad don't know what to do ?
                • mariochaM Offline
                  mariocha
                  .... Perhaps you could test it for me -- I don't have a computer with Mavericks.
                  I will sure be glad to give it a try, Doug.
                  Your plugin is a must for me.
                  updt: Received a beta, works just fine. β˜€ πŸ˜„
                  updt: New version 1.8.4 available on the Regular Polygon website.
                  %(#008000)[Mario C.
                  • mariochaM Offline
                    mariocha
                    Just for info.
                    Here there is no problem importing dwg files, on both my computers under Maverick.
                    %(#008000)[Mario C.
                    • mariochaM Offline
                      mariocha
                      • My tool palettes ( Layers, Style, Scenes, etc ) don't "stick" together anymore. When I click on them to enlarge, they just dissociate from the others, which is pretty annoying. ...
                      It is indeed pretty annoying. It was a very appreciated feature. Hoping a maintenance update will correct that ! Please ?
                      updt: My wish for the new year !
                      %(#008000)[Mario C.
                      • H Offline
                        hambuild
                        @martychristoffel said:
                        I'm running into palettes that are no longer "sticky" since upgrading to Mavericks. To be more precise, although the palettes do snap to one another, when expanding one such as the Layers palette, it opens underneath the minimized Styles, Scenes, etc. instead of having those palettes remain connected to the Layers pane. When minimizing them down to their title bars, they can also lose their relative association to other palettes.
                        ME Too!
                        • mariochaM Offline
                          mariocha
                          2014 Sticky palettes are back !!!
                          Now how about bringing back thumbnail icon of SkUp files in Finder. Was there up to v8. So practical.
                          Anyway very happy with v2014. Full congrats to the SU team ! πŸ˜„
                          %(#008000)[Mario C.
                          • 5 / 5
