    3D model of hill-like structures using SketchUp C SDK
    12 Posts 3 Posters 2.4k Views 3 Watching
      SrutiDavis
      Hi everyone,
      I'm trying to draw sand dunes or hill-like structures using the new SketchUp C SDK on Visual Studio. I was wondering if someone has done this before or if at all this is possible. Any suggestions?
      Also, I went through the header files that came along with the SDK and I feel it's not possible to do terrain modification using the SDK. Do you guys agree with that?
      Lastly, is it true that the Ruby API cannot be used from an application other than SketchUp? If that's not true, then can I use Ruby API for terrain modification or creation of 3D models to produce sand dune-like structures?
      • tt_suT
        tt_su
        The Ruby API can only be used from within SketchUp, correct.
        As for the C SDK, where are you stuck? What prevents you from creating terrain geometry? The C API is generic, there is no limitations imposed to what it creates - so creating terrains will be possible.
          SrutiDavis
          As for the C SDK, where are you stuck? What prevents you from creating terrain geometry? The C API is generic, there is no limitations imposed to what it creates - so creating terrains is be possible.
          Hi tt_su,
          Thanks for your reply. I'm new to SketchUp and so far I have only been able to create regular shapes such as a cube or a 2D face using the SDK. How does one go about creating terrain geometry such as a sand pile? Please give some suggestions.
          • Dan RathbunD
            Dan Rathbun
            You would first create a virtual mesh (a Geom::PolygonMesh object. All classes in the GEom module are virtual memory objects, not actual model Sketchup::DrawingElement subclasses.)
            Then to port the mesh to the model, you use Entities#add_faces_from_mesh() or Entities#fill_from_mesh().
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              Then to tweak your mesh, you can get TT's Vertex Tools
              http://www.thomthom.net/software/vertex_tools/
              http://www.thomthom.net/software/vertex_tools/images/VertexToolsTincan.jpg
                SrutiDavis
                Hi Dan,
                Thanks for your reply. The methods and objects you proposed are from the Ruby API. I want to be able to do the same using C API since I am working from another application and not using the SketchUp interface.
                So how can I create terrain geometry using the C API?
                • tt_suT
                  tt_su
                  If you observe the construction of the mesh that Sandbox you'll see that each square is made up of two triangular faces with a soft+smooth edge shared between them.
                  If you have your set of 3d points that represent the sand pile you'd iterate over it, generating the triangulation needed.
                  • tt_suT
                    tt_su
                    That doesn't apply to this particular question though, as he's trying to use the C API to generate the geometry.
                    • Dan RathbunD
                      Dan Rathbun
                      Sorry.. but does the C API have interfaces for Geom classes ?
                      Does it have an interface for add_faces_from_mesh ?
                      • tt_suT
                        tt_su
                        The C API interfaces with the SketchUp core, it does not interface with Ruby.
                        There are similar functions though, such as SUEntitiesAddFaces and SUEntitiesFill, but they are not 1:1 mappings.
                        • Dan RathbunD
                          Dan Rathbun
                          OK thanks. I have not had time to delve into it yet.
                          I thought it would have virtual helper classes like the Ruby API has in the Geom module.
                          But I suppose being C, there is a wealth of such libraries that a C programmer could choose to use, even OpenGL, or MS GDI libs ?
                          • tt_suT
                            tt_su
                            There is, yes. But the C API isn't finalized either. It's still being developed and we are improving it to make it have a similar coverage as the Ruby API.
