Importer textures photographiques Google earth
Hello! 1er post par ici
Je ne parviens pas à importer la texture photographique de Google earth: je vais jusqu'à capter un cadrage de l'image choisi sur GE, mais pas moyen de la récupérer su SU... -
J'avais le même problème.
La solution ici:
[Original Post]
Within the next 24hours, Google will stop supporting the Google Maps API version 2 (learn more). SketchUp uses this API in a number of features, including Add Location, Generate Report, and Photo Texture. To resolve this issue, Trimble/SketchUp will be hosting version 3 of the Google Maps API for our users, and Google will redirect SketchUp traffic from their servers to these new Trimble servers. Since we are switching both the version and the location of the API, users and customers may encounter some issues. Specifically...
Add Location in SketchUp 8 and SketchUp 2013 on Mac OS X 10.7 and 10.8 may stop working all together (confirmed: see updates below). OS X 10.9 Mavericks seems to resolve this issue.
Generate Report may not show any content, or you may not be able to click on any of the content.
Photo Texture feature may not render any map or Street View data.
If you encounter any of these issues starting in the next 24 hours, feel free to reply to this thread with the operating system you're using, the version of SketchUp you're using, and the issue that you're seeing.Many thanks!
UPDATE 11/19/2013 9:45am MST
The change appears to be live.UPDATE 11/19/2013 10:30am MST
Known Issue: Add Location doesn't work on SketchUp 2013 and SketchUp 8 on Mac OS X 10.8 (Mountain Lion) and older versions of OS X. If you're using OS X 10.9 (Mavericks) you do not have to make this change. To resolve this issue, please follow these steps:For SketchUp 2013
Close SketchUp
Open a new Finder window.
Open the Applications folder, then open "SketchUp 2013" folder.
Right-click on the SketchUp application and click "Show package contents."
Open the Contents folder, then open the Resources and then Content folder.
Right-click on the "SketchUp.dat" file and select Open With > TextEdit, or your favorite text editor.
Locate the following line: MODEL_HERE_DIALOG={WAREHOUSE_SERVER}/3dwarehouse/skpaddlocation?hl={GWS_CULTURE}
Replace the line in step 6 with the following value: MODEL_HERE_DIALOG=http://help.sketchup.com/sites/help.sketchup.com/files/product/addlocation.html?hl={GWS_CULTURE}
For SketchUp 8
Close SketchUp
Navigate to the following folder: MacintoshHD/Library/Application Support/Google SketchUp 8. Note that this folder is different from the user-level Library folder.
Click File > Save and close your text editor.
Known Issue: The Generate Report and Get Photo Texture feature are now permanently broken in SketchUp version 7. Unfortunately, there is no way to correct this issue, and you may consider using SketchUp 8 or SketchUp 2013/Make.UPDATE 11/22/2013 5:15pm MST
Known Issue: (SketchUp 8 on Windows) If Add Location does nothing after you click Grab, you may have an older version of SketchUp 8 installed on your computer. Please visit this page to download and install the latest version of SketchUp 8.UPDATE 11/25/2013 11:30am MST
Generate Report blank - If you're on OS X 10.9 Mavericks and it's still not loading, delete the following two files that may be affecting this:SketchUp 2013
~/Library/Caches/com.sketchup.SketchUp
~/Library/Saved Application State/com.sketchup.SketchUpSketchUp 8
~/Library/Caches/com.google.sketchuppro8
~/Library/Saved Application State/com.google.sketchuppro8NOTE: ~ (tilde) means "Your Home Directory". An easy way to get to these folders is to open a Finder window, click "Go" in the top menu bar, then click "Go to Folder..." Then, copy and paste the folder paths, but note the file name, that are noted above into the text box ( eg. ~/Library/Caches ) and press return.
Salut et bienvenue !
Le plus simple pour faire ça est... de ne pas utiliser GoogleEarth pour le faire !
Dans SU, palette "Infos sur le modèle", rubrique "Géoposition" :
- Cliquer sur "Ajouter un emplacement", une fenêtre GoogleMap s'ouvre (GoogleMap et GoogleEarth ont la même source d'images),
- naviguer pour afficher le site voulu,
- régler l'échelle à volonté, cliquer sur "Sélectionner une région",
- faire sa sélection avec les punaises de coins puis cliquer sur "Capter". Ça a pour effet d'intégrer dans le fichier SU deux surfaces, l'une plane qui s'appelle par défaut "Google Earth Snapshot", l'autre en relief (le relief grossier du lieu choisi) avec l'image satellite projetée qui s'appelle par défaut "Google Earth Terrain". Chacune des 2 surfaces étant sur des calques séparés. Les 2 surfaces sont superposées en Z.
Tu peux par le suite agrandir ton terrain via le bouton "Ajouter plus d'images" du menu "Géoposition".
Cela répond-il à ta question ?
Merci Chon pour ta réponse claire: bon tuto pour importer textures photographiques Google earth, mais mon problème n'est pas résolu.
Merci Gilles de compatir.
Je travaille sur SU 8 sur PC, j'ai trouvé le fichier "SketchUp.dat" dans le dossier "support" puis remplacé la ligne comme indiqué dans ton post mais on me refuse l'enregistrement...
(c'est la première fois que je me penche sur une ligne de code)
Vérifie que tu a toutes permissions pour ce fichier, lecture et écriture et avant de le modifier fait une sauvegarde ailleurs au kazoo.
Bravo les gars, j'ai réussi grace à vos 2 réponses
@gilles
en effet j'ai du me donner l'autorisation d'écriture sur ce fichier pour pouvoir changer la ligne en question.@chon
c'est en effet en passant par GoogleMap que j'y parviens.Mais j'ai une autre question
par ce moyen je parviens à récupérer une texture de GoogleMap, mais pas à passer au point de vue de GoogleStreetview...
