    Using each_slice possible?
    10 Posts 2 Posters 1.3k Views 2 Watching
    • F Offline
      Frankn
      I have a feeling this is a stupid question but I can't find the answer!
      I need to use each_slice in a plugin I'm working on but can't get it to work... I keep getting Error: #<NoMethodError: undefined method `each_slice' for #Array:0xc6c8c14>.
      Thanks in advance!
      Frank
      • F Offline
        Frankn
        Thanks Dan!
        But I get this error now...
        Error: #<NoMethodError: undefined method `abs' for Math:Module>
        • Dan RathbunD Offline
          Dan Rathbun
          Fixed absolute call (in example above.)
          It is not a Math module function. It is a standard Ruby Numeric instance method.
          I just assumed the Math module would have an "abs" function. 😳
          The absolute call is to prevent an Index error:
          ary.slice!(0,-3) %(#004000)[Error: #<IndexError: (eval):0:inslice!': negative length (-3)>]`
          I'm not here much anymore.
          • F Offline
            Frankn
            Thanks Dan that works awesome!
            Now I'm having the same problem with delete_if! Isn't there an addon or file we can download to get the missing methods? If not how do you know figure out how to make new ones as you did? I don't want to have to bother anyone the next time I get a similar error if I can fix it myself.
              Dan Rathbun
              @frankn said:
              Now I'm having the same problem with "delete_if!"
              That is because the method's name is delete_if.
              There is no exclamation point name.
              You should refer to the documentation for Ruby v1.8.6 when programming for Ruby v1.8.6.
              RUBY PROGRAMMING REFERENCES
              • F Offline
                Frankn
                I was actually using the ! as punctuation not in my code.
                BUT reading your post made me realize I had made typo somewhere else in my code causing the error.
                Thanks again for your help sir.
                  Dan Rathbun
                  There may be a "Backport" gem for Ruby v1.8.6 that adds later methods.
                  But you would need to convince all users to install it. It also may not have ALL the new methods in later versions (such as v1.9.x or v2.0.x.)
                  I do not know how to answer that. Many many years experience.
                  Read as many books on Ruby as you can.
                  Keeping trying and failing, until you gain success ?
                    Dan Rathbun
                    Here is another edition that will collect the slices into an output array, IF a block is NOT given. (Sort of like the opposite to flatten().)
                    If a block is given, it returns an array of the block's return values.
                    Prints to $stdout only if $VERBOSE == true.
                    def slicer(ary,num)
                      a2 = ary.dup
                      len = num.to_i.abs
                      out = []
                      until (s = a2.slice!(0,len)).empty?
                        puts(s.inspect) if $VERBOSE
                        if block_given?
                          out << yield(s)
                          puts( out.last.inspect ) if $VERBOSE
                        else
                          out << s
                      end # until
                      return out
                    end # slicer()
                    πŸ’­
                    EDIT: fixed puts'ing block results
                      Dan Rathbun
                      EDIT: fixed puts'ing block results in the 2nd example.
                        Dan Rathbun
                        You get a NoMethodError because Enumerable does not have that method defined in Ruby 1.8.x.
                        This should do the same, except you pass the array in as the 1st argument:
                        def slicer(ary,num)
                          a2 = ary.dup
                          len = num.to_i.abs
                            if block_given?
                              yield(s)
                            else
                              puts(s.inspect)
                          end # until
                        end # slicer()
                        See another example that will collect the slices into an output array, IF a block is NOT given. (Sort of like the opposite to flatten().) If a block is given, it returns an array of the block's return values. Prints to $stdout only if $VERBOSE == true.
                        πŸ’­
                        Fixed absolute call. It is not a Math module function. It is a standard Ruby Numeric instance method. 😳
