    Edge intersection
    5 Posts 3 Posters 443 Views 3 Watching
      sandbox_4
      Hello, I need to know if an edge is intersected by any entity (group, face,component)
      for example in this case:
      ----------------[face]--------------------- there is a face in the middle of the edge
      i need a function like
      edge.is_intersected? true
      -------------------------------------------- in this case theres nothing in the edge so
      edge.is_intersected? false
      But i dont need a function like (edge.is_intersected_with? face), I just want to know if an edge is intersected by anything. I tried with all_connected, faces, but it doesnt work
      Thank You
      • Dan RathbunD Offline
        Dan Rathbun
        No the API does not have any instance method like that, for the Edge class.
        Generally instance methods return information that the object knows about itself. In SketchUp edge objects are rather dumb about other objects that have not interacted with themselves.
        You would have to go UP one editing context, and ask THAT context ( Entities collection,) if the two objects intersected.
        Also it is against the API law to create new instance methods. (Only Trimble should modify the API.)
        The closest thing you might find, is*:
        ` result = edge.bounds.intersect(face.bounds)
        if result.empty?
        they did not intersect
        else
        they do intersect
        end`
        See Geom::BoundingBox#intersect()
        • not a warranty that this will be the solution
        There are also Geom module intersect functions.
        πŸ’­
        I'm not here much anymore.
        • AdamBA Offline
          AdamB
          Thank You
          Do really mean an Edge? As in you don't just want to test whether a ray (an imaginary line in space) intersects an entity, you really want an Geometric Edge (and all the semantics that go with it)?
          Adam
            sandbox_4
            Adam
            Yes I need to know if the direct path (a imaginary line ) between 2 entities is obstructed or not
            For example
            [entity1]--------------------[entity2]
            in this case theres nothing in the direct path between the entities so i need a function like entity1.line_of_sight? entity2 true
            but in this case
            [entity1]------[cube]---------[entity2]
            theres a cube in the direct path so the direct path is obstructed then
            entity1.line_of_sight? entity2 false
              Dan Rathbun
              Sketchup::Model#raytest()
