    Soften coplanar ?
    22 Posts 4 Posters 3.5k Views 4 Watching
    • jolranJ
      jolran
      Yeah, that works for me too.
      rest of code ? I'm just grepping edges after add_faces_from_mesh.
      And then running the code you provided.
      Had to use add_faces_from_mesh not to get smoothed edges (?).
      Strange.. Must have broken something cause did not have any problems with fill from mesh before. Need to laborate with the fill_from_mesh parameters..
      edit: β˜€ must have removed the second parameter in fill_from_mesh( mesh, true, 0)
      accidentially. now it works, and much faster!
      edges = bake_group.entities.grep(Sketchup;;Edge)
      for e in edges
         next unless e.faces.length==2 && e.faces[0].normal.parallel?(e.faces[1].normal)
         e.soft = true && e.smooth = true
      • jolranJ
        jolran
        This gives a little more flexibility if put as options. Could be better written..
        Bit dangerous deleting edges like that..
        # Options for ex dialog
        delete_coplanar = true
        angle_a = 0.001
        angle_b = 35
        for e in edges
          next if e.deleted?
          next unless e.faces.length == 2
          ang = e.faces[0].normal.angle_between(e.faces[1].normal)
          case ang
          when delete_coplanar && 0.degrees
            e.erase!
            next
          when [angle_a, 0.0001].max.degrees...angle_b.degrees
            e.soft=true && e.smooth=true
          when ang > angle_b.degrees
            #e.material = "red" #debug!
            e.soft=false && e.smooth=false
        • tt_suT
          tt_su
          Checking the normal isn't going to give correct result in all cases. You'd need to check if all the points of the faces all lie on the same plane.
          • jolranJ
            jolran
            The polygonmesh class is really a piece of art filled with mysterious behavior.
            Dug up this old thread:
            404 Not Found
            (sketchucation.com)
            It does not seam to be accurate what says there.
            I'm using Thomthoms example for hidding edges with negative index values.
            Creating a Group and adding entities with add_faces_from_mesh or fill from mesh.
            Following that example mesh.add_polygon(1,-2,3) etc. Using positive values VS negative values has no effect.
            No smooth_flags argument sets default to (12 ?)
            So using mesh.add_polygon(1,2,3) gives same result as mesh.add_polygon(1,-2,3)
            Am I missing something ? There's no follow up in that thread stating what I'm experiencing here..
            • jolranJ
              jolran
              Yeah, I noticed some "irregularities" during some tests. This won't cover all scenarious, and to add many validychecks on top of fill from mesh would be to compute intensensive when dealing with plenty of geometry.
              Since TIG is not a "mindreader" ( or is he πŸ˜„ ), I probably should have mentioned that the motif for creating this method is to try to restore a polygonsmesh to it's true geometry when baking. And the true meaning faces from a Component or Group.
              Unfortunately if having faces with holes they don't come out well when baking the mesh unless I triangulate the faces. And since I probably will do something to the Mesh, the original face-Component cannot be used as a reference for removing holes after an intersection. At the moment I'm only triangulating faces with 5 or more vertices..
              A face with a hole have minimum 6 vertices (?)
              edit: removed some irrelevant...
              • tt_suT
                tt_su
                Yes, I recently discovered what was really going on here. We have updated docs pending for release.
                Entities.fill_from_mesh:
                • The weld_vertices has no effect. This is because the PolygonMesh merge points as well.
                add_faces_from_mesh & fill_faces_from_mesh - smooth_flags:
                This is a bit flag composed of these flags:
                0 No smoothing
                1 Negative point index will hide the edge.
                2 Negative point index will soften the edge.
                4 Interior edges are softened. (Ignores the sign of the index)
                8 All soft edges will also be smooth.
                Default value is 4 | 8 (12)
                So if you want to create a mesh where you control the smoothing of each edge:
                2 | 8
                entities.fill_faces_from_mesh(mesh, true, 2 | 8)
                The current docs are just plain wrong. We'll probably introduce constants for these values in the future - to avoid developers using magic numbers.
                • jolranJ
                  jolran
                  That's awesome news!
                  entities.fill_faces_from_mesh(mesh, true, 2 | 😎
                  Right. Will try that.
                  I persume you mean one can choose between 2 or 8, not apply expression in argument?
                  • jolranJ
                    jolran
                    fill_faces_from_mesh ? Typo ?
                    • jolranJ
                      jolran
                      2 | 8
                      Expression it is! Yei! It works.
                      • Dan RathbunD
                        Dan Rathbun
                        | is the Integer BITWISE OR operator (really method name.)
                        Both subclasses ( Fixnum & Bignum) have this method.
                        see:
                        http://www.ruby-doc.org/core-1.8.6/Fixnum.html#method-i-7C
                        πŸ€“
                        I'm not here much anymore.
                        • Dan RathbunD
                          Dan Rathbun
                          Also there are many API methods that allow bit mask Integer arguments, where you can combine different bit flags using **|**.
                          Some are not documented, like the 2nd arg to UI.messagebox can also (in addition to the button flag,) be OR'd with an icon integer flag that sets which standard icon (or none,) is displayed in the messagebox.
                          • jolranJ
                            jolran
                            ahh, nice info. I've used bitwise in JavaScript ( for performance reason ). Good to know they work in Ruby as well.
                            How the heck do you guys know all this ? πŸ˜„
                            Must spend a lot of time experimenting outside the docs..
                            • tt_suT
                              tt_su
                              Heh! Docs? The docs where in a very poor state five/size years ago. Poking about was the way to go.
                              (Not saying that the docs now are "good" or anything though... ...just that they where a lot worse.)
                              • tt_suT
                                tt_su
                                Yes - should be "fill_from_mesh". 😳 Just love the consistency of the Ruby API naming... πŸ˜’
                                • jolranJ
                                  jolran
                                  I had to ask, thought there where some new hidden stuff πŸ˜„
                                  • tt_suT
                                    tt_su
                                    Yes, you never know.
                                    • jolranJ
                                      jolran
                                      entities.fill_from_mesh(mesh, true, 2 | 8) is working nicelly, but a small gotcha..
                                      %(#FF0000)[mesh.add_polygon(1,2,3)
                                      mesh.add_polygon(2,3,4)]
                                      Does gives hard edges, as expected.
                                      %(#FF0000)[mesh.add_polygon(1,-2,3)
                                      mesh.add_polygon(-2,3,4)]
                                      gives hard soft edge between Points 2, as expected.
                                      but so does this:
                                      or
                                      So I'm starting to see some trouble with this method. To be able to stear edge visibility one need to use 2 Points in comparison. For ex a Collection of edge.start and end positions.
                                      For a triangulated quad this works but not if the face has innerloops,
                                      Or faces where triangulation is splitting the face without hitting innerloops.
                                      Was to fast here..
                                      The docs actually explains this behavior, "value of [-1, 2, 3] indicates that the edge from 1 to 2 is hidden"
