    Menue definition - small problem
    3 Posts 2 Posters 331 Views 2 Watching
    • artmusicstudioA
      artmusicstudio
      hi,
      with my code i have the following problem:
      every time i restart the ruby in the ruby console per
      load '01.rb'
      the menue entry in the plugins-menue is duplicated (so after 5 calls 5 times the menue, the first one at the top, all the others then call by call at the botton of the plugins menue...))
      where is the problem?
      Sketchup.send_action "showRubyPanel;"
      submenu = UI.menu("Plugins").add_submenu("01-zf-ruby")
      submenu.add_item("1 ruby"){
      meth_1
      meth_2
      submenu.add_separator
      submenu.add_item("2 save last model"){
      meth_3
      meth_4
      submenu.add_item("3 load saved model"){
      meth_5
      meth_6
      submenu.add_item("4 support"){
      UI.messagebox "support" # w.i.p.
      thanx for checking and helping.
      stan
      • Dan RathbunD
        Dan Rathbun
        @artmusicstudio said:
        ... every time i restart the ruby ... the menue entry in the plugins-menue is duplicated ... where is the problem?
        Use a block of code that runs only ONCE per session:
          ### load SketchUp global methods so we can
          #    use file_loaded?() and file_loaded()
          require("sketchup.rb")
          THISFILE = File.basename(__FILE__)
          #{# RUN ONCE PER SESSION
          unless file_loaded?(THISFILE)
              meth_1
              meth_2
              meth_3
              meth_4
              meth_5
              meth_6
            # mark THISFILE as loaded;
            file_loaded(THISFILE)
          end #}# RUN ONCE PER SESSION
        I'm not here much anymore.
        • artmusicstudioA
          artmusicstudio
          hi dan,
          super, thanx, i understood and it works now,
          besides a small message in the console:
          load '01.rb'
          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:66: warning: already initialized constant THISFILE
          true
          i start the ruby directly, not in a module (when i put it in the module, it does not work, probably because of all the entities definitions etc. / still workin' on it)
          regards stan
