    Artisan Plugin (SDS2).....Cave
    47 Posts 19 Posters 18.2k Views 19 Watching
    • olisheaO Offline
      olishea
      No UVs exactly. It was a really good seamless texture, its dirty concrete so its hard to tell if the alignment isn't correct. Any places where it was a bit distorted I used the paint brush tool in artisan. I have the material if anyone wants it, also the thea .mat file.
      If you were gonna do this properly, would slice the columns and the top and bottoms (using knife tool)....then cylindrically map the texture onto them. The walls and floor could just be textured seamlessly, no UVs.
      Pixero, you are given a preview of the subdivision so you don't actually have to execute the command. I just click space bar and it returns to the proxy. The preview will let you change the amount of iterations also....but once you have executed the subdivision/smoothing then you would have to 'undo' to get back to proxy.
      oli
      • soloS Offline
        Pixero, when you select to subdivide you get a preview and an option to contine (hit enter)
        See images, first the basic proxy:
        Then here is the 'Preview' of how it will look with 3 iriterations:
        And then finally how it looks after subdivision:
        • KrisidiousK Offline
          Krisidious
          that is so awesome.
          By: Kristoff Rand
          • olisheaO Offline
            olishea
            it should be noted that artisan works on remote parts of a mesh and doesn't have to affect all of it.
            with subdivide and smooth 1 you could not select part of a mesh and subdivide it without affecting the whole surface.
            great if you want to smooth just a portion of a mesh, see screenshot.
            oli
            • michaliszissiouM Offline
              michaliszissiou
              πŸ‘
              Exactly,
              BTW to smooth the whole thing you must have a better computer than the one you have now. 🀣
              @solo
              Better to avoid smoothing on stretched faces like the ones you used on your fast version of cave. You wont be able to texture this stretched result decently.
                Krisidious
                for how far into the future can I expect to keep seeing plugins like this? when will SU ever reach it's Pinnacle? this is very exciting stuff. I don't even do very much organic modeling and it excites me... I can't imagine what the organic modeling people are thinking.
                By: Kristoff Rand
                • Z Offline
                  zikanglim
                  @olishea said:
                  thanks man hehe, i'm making a tutorial for this scene...from modeling to rendering to photoshop touch-up. It could literally be made in minutes, although it took me hours of fannying around. πŸ˜†
                  Hey do you think I can get the tutorial video website from you? Would love to learn modeling the caves. Please πŸ˜„
                  • olisheaO Offline
                    olishea
                    I never actually got round to making a full tutorial for this scene. Work kinda got in the way. It really is not difficult; the texture works because it's relatively seamless in both directions.
                    Repeating what I wrote earlier, the image should really help explain it:
                    a view from above. look how clean the mesh is around the column caps, its completely homogenous, no intersecting or anything....thats a typical proxy to the right. Deleting internal faces helps create a clean result. (remove inner faces.rb). this is an early version of the model before I sculpted the floor, notice how it was flat.....you can paint contours into it. πŸ˜„ i removed the walls for clarity....they were made using the free hand tool, push pull and then artisan, about 5 minutes each.
                    http://i654.photobucket.com/albums/uu269/olishea/Picture59.png
                    oli
                      jpalm32
                      Very interesting work Oli.
                      How large is it with the walls?
                      • olisheaO Offline
                        olishea
                        Thanks jpalm, I wish I had more time to keep making models like this.
                        It wasn't very large at all, most of the file size came from the texture. It was very fluid and easy to navigate.
                        I forgot to mention I used sketchup's native "from contours" tool (sandbox) to link up the tops and bottoms of the "columns"...this was then subdivided a few times.
                        The morning Thea render had no direct light; only physical sky was used to give a general glow. I love Thea's physical sky. For the afternoon shots I used direct sunlight and physical sky combined. For the misty afternoon shot I added the volumetric fog in photoshop, bit of a cheat really but I never got my head round volumetric materials especially as my dual core computer was rendering them soooooo slooooooow! πŸ˜†
                        41MB in total
                        477,526 edges
                        314,374 faces
                        If anyone wants me to upload this model for playing/rendering let me know and I'll make a download link. πŸ˜„
                        oli
                        • 3 / 3
