    Controlled Drop with Thruster?
    5 Posts 2 Posters 4.9k Views 2 Watching
      twharvey
      I building a clock model where the diving force in the real clock is a weight that drops puling a string that in turn unwraps from a drum, thus driving the clock mechanism. To make the simulation, I'm using a motor on the drum to drive the clock. I would like to have the weight drop at a controlled rate that would mimic the action of the real thing. I tried using a thruster on the weight with a negative number in the strength box thinking to adjust the strength number to set the rate of decent, but it just drops as if it were a group with no connection, when the simulation is run.
      Does anybody know how to make an object drop at a designated speed?
      Any ideas would be appreciated,
      Tom
        mptak
        What you describe should have been possible especially if you had a gyro attached. You are probably trying to avoid this but functions from the sketchy physics library like teleport or setVelocity would probably work.
          twharvey
          Thanks, mptak, those sound like just what I need, but where can I find this SketchyPhysics Library?
          Tom
            mptak
            https://code.google.com/p/sketchyphysics/wiki/ScriptFunctions
              twharvey
              Thanks, mptak.
              I've got it working! In case anybody else needs to do it, here's the model of the weight falling.
              ControlledDrop1.skp
              Tom
