    [code] Sketchup Safe Shutdown method
    10 Posts 4 Posters 5.6k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      • EDIT: Since SketchUp 2014 the added method shown in this topic thread is no longer needed.
      • Since that release, the API defines a Sketchup.quit module method that shuts down SketchUp safely.
      Introduction
      After reviewing the postings listed in the section Historic Reference (see below), it's time to post a simple, cross-platform safe shutdown Ruby method. (ie: The equivalent of the user choosing File > Exit or clicking the Titlebar X button.)
      Release - v1.0.0 - 27 DEC 2010
      • Tested on PC v7.x and 8.x* The Mac Cocoa 'terminate:' id should work for all OSX vers.
      #  app_safe_shutdown.rb
      #  defines Sketchup;;app_safe_shutdown method
      #  by Dan Rathbun - Palm Bay, FL, USA
      #  Public Domain
      #  version; 1.0.0 - 27 DEC 2010
      module Sketchup
        # check first if Google has added this method
        unless method_defined?( ;app_safe_shutdown )
          if RUBY_PLATFORM.downcase.include?('mswin')
            # add Windows method
            def app_safe_shutdown
              send_action( 57665 ) # v7 and v8
            end # def
            module_function(;app_safe_shutdown)
          elsif RUBY_PLATFORM.downcase.include?('darwin')
            # add Mac OSX method
              # per Greg Ewing
              send_action('terminate;')
            end # def
          else
            # Unsupported platform > silently do nothing!
          end # if
        else
          # already defined
          unless $VERBOSE.nil?
            $stderr.write('Notice; #<!; method Sketchup;;app_safe_shutdown was already defined. ')
            $stderr.write("Script&#058; '#{File.basename(__FILE__)}' did NOT redefine the method!>\n")
        end # unless
      end # module
      Historic Reference
      Posts on this issue here at SCF:
      • Exit/Shutdown SU 7 ??
        Posts on this issue at GoogleGroups:
      • Is it possible to initiate the termination of SketchUp from the Ruby script?
      • Ruby Command to shutdown Sketchup
      • Closing Sketchup from a Ruby script
      http://devimages.apple.com/assets/elements/header/developer.png
      • Mac OSX
      (http://developer.apple.com/mac/library/documentation/Cocoa/Reference/ApplicationKit/Classes/NSApplication_Class/Reference/Reference.html#//apple_ref/occ/instm/NSApplication/terminate;)":35u8ppdq]
      %(#000000)[**terminate:**]
      Terminates the receiver.
      %(#008B8B)[(void)terminate:(id)sender]
      Parameters
      sender
      Typically, this parameter contains the object that initiated the termination request.
      Discussion
      This method is typically invoked when the user chooses Quit or Exit from the application’s menu.
      When invoked, this method performs several steps to process the termination request. First, it asks the application’s document controller (if one exists) to save any unsaved changes in its documents. During this process, the document controller can cancel termination in response to input from the user.
      .... ( for more, see link )
      I'm not here much anymore.
        Jim
        Seems to work fine for me, Dan.
        I tested new, saved, and changed models under WinXP.
        Is it possible to automatically restart SU somehow, maybe after a short delay?
          Dan Rathbun
          PC
          I did verify with VisualStudio that all PC versions above 6 have the ID 57665 for File > Exit.
          (I did download ver 6, just to check it, but haven't had a chance to install it yet.)
          Mac
          The ':terminate' string is a Mac Cocoa automation command, so it should also work for all Mac versions running OSX.
            Dan Rathbun
            A Ruby note: I'm UNsure how well this conditional works:
            unless ( defined? app_safe_shutdown )=='method'
            It seemed to, later playing around, it seemed NOT to work.
            I may need to change that to just:
            unless method_defined?( :app_safe_shutdown )
              Dan Rathbun
              Hmm... With a batch cmd file.. sure; but it would have had to start Sketchup in the first place.
              Having the app itself restart itself... I'll need to think about that.. I'm sure I could whip out a VBS script that could restart SU.
                Jim
                Please don't spend time on this (unless you can't help it!) It's not terribly important and my fingers are not broken.
                  Dan Rathbun
                  I will say that you should consider creating a Ruby method that makes a Win32API call to CreateProcess so that the Restart utilty can begin without being 'held up' by Sketchup's Ruby process.
                  If you attempt to use Ruby's system(), IO.popen or shell %x(*command string*) (ie, the Kernel 'dot' backquote method,) .. Ruby cannot continue until the call returns, because they create subprocesses.
                  Otherwise you'd be forced to use a nested external script. Ruby calls the a 'parent' script, which starts the restart script as a new process, so "it" (the parent,) can finish, and return to the Ruby system() call.
                    cjthompson
                    For at least IO.popen, ruby will continue until you start reading on the pipe, although I have a feeling I took your statement out of context.
                      Dan Rathbun
                      Yea, kinda. Trying to shut Ruby and Sketchup down (cleanly,) and don't really want a pipe.
                        driven
                        censored
