    You are now editing multiple components
    56 Posts 6 Posters 7.6k Views 6 Watching
    • Dan RathbunD
      Dan Rathbun
      @ashscott said:
      Being a test concept, do you want me to take down the .rb link?
      It would be best, for now.. as the toplevel module has the standard example name Author which is meant to be replaced with a REAL author's toplevel module name.
      If you release an edition of it.. the toplevel module would be named Scott or Ash, or whatever you decide, perhaps a company identifier for your toplevel namespace. Choose something that is unique, or not yet used by anyone else, and does not violate any enitity's trademark.
      I'm not here much anymore.
      • ashscottA
        ashscott
        This sketchyphysics model modifies the watermark text in realtime during a simulation based on user inputs....not sure if its any help for this problem: http://sketchup.google.com/3dwarehouse/details?mid=5b618d4ba6c22ca85fd35d52fb19ea9b&prevstart=0
        Just some stuff I do with Sketchup.
        • T
          Trogluddite
          Hi There,
          Just wanted to say thanks, Ash, for the idea; and Dan for for the sterling work putting it into practice.
          I very often derive components in a model from other template parts, and I forget to click "make unique" about 50 times a week!
          Having a warning that pops up regardless of the 'hiding other stuff' settings is something that could save me oodles of time re-loading components or going back to previous file version.
          • ashscottA
            ashscott
            That is awesome, pretty much the exact functionality I was looking for.
            Just trying to figure out how to make that text bolder...
            • ashscottA
              ashscott
              Tell me about it. I was certain someone must have written a script to do this but I had a browse around and it appeared they hadn't.
              Frankly, I think the lack of a warning like this plugin and the errors it causes for users (who are focusing on what they are drawing on not how many components they are messing with) is a limitation to the efficiency of sketchup as many users don't use components to their full potential because they have been burned in the past.
              When I concentrate really hard I can draw parts and assemblies with a lot more speed using components but the concentration required to keep track of what other parts I am modifying is a drain.
              I hope this enables people to get right back into using components to their full potential.
              • Dan RathbunD
                Dan Rathbun
                @ashscott said:
                This sketchyphysics model modifies the watermark text in realtime ...
                Warkmarks are images, and currently have no exposure in the API.
                They are a no go, at this time.
                Besides that example would require users to install SketchyPhysics, which has some "naughty poor programming" issues at this time. (But should be fixed soon.)
                • ashscottA
                  ashscott
                  Has anyone else with a bit more ruby experience than me had a chance to tinker with the sketchyphysics model I linked to (above) and worked out how it modifies the watermark in real time depending on user's inputs? Is it something to do with the sketchyphysics runtime (requires sketchyphysics running?) or could it be applied to our current problem?
                  • Dan RathbunD
                    Dan Rathbun
                    Perhaps it directly manipulates an external watermark image file ?
                    • ashscottA
                      ashscott
                      I don't know how this works but as far as I can tell this is the line that controls it:
                      logLine "mode;" + @@hokou.to_s
                      Have poked around the documentation but I'm not really sure what logLine does
                      • Dan RathbunD
                        Dan Rathbun
                        it looks like a method call
                        • ashscottA
                          ashscott
                          Any use for the problem we have here?
                          • Dan RathbunD
                            Dan Rathbun
                            I do not have the SketchyPhysics code downloaded, so I cannot look at it.
                            • T
                              Trogluddite
                              Interesting - just stumbled over this thread as I was wanting to do something similar - a constant tally of faces in the corner, as I'm working on some models where minimal poly count is critical.
                              I did a text search through the SketchyPhysics .rb files to see how they did it, and found an 'addWatermarkText' method.
                              Seems it's not a watermark at all, but a 'face-me' text component, loaded from a support folder, and placed using 'pickray' to find it a consistent location on screen.
                              Presumably this means that it has its position transformed whenever the view is orbited etc., though I didn't have the patience to go looking through all of the files for the method calls.
                              • ashscottA
                                ashscott
                                Awesome sleuthing!
                                • Dan RathbunD
                                  Dan Rathbun
                                  Seems it's not a watermark at all, but a 'face-me' text component, ...
                                  This is how I am currently doing it (in (WIP) Edit Mode Warning Flag v1.1.0,) using:
                                  model.add_note(@note,@x,@y)
                                  This above method creates a special viewport-based "face camera" Sketchup::Text object.
                                  @trogluddite said:
                                  ..., and placed using 'pickray' to find it a consistent location on screen.
                                  Presumably this means that it has its position transformed whenever the view is orbited etc., ...
                                  The view-based Text object does this automatically, but the x and y are percentages, so it can handle viewport resizing better.
                                  But the main drawback is that using a Drawingelement always modifies any model file opened.
                                  I CAN make a transparent window or WebDialog on PC. John (Driven) already has done work on this for the Mac.
                                  • ashscottA
                                    ashscott
                                    Do we have any more options with the advent of SU 2013?
                                    What can I do to help move this forward as I'm struggling with some of the documentation again - is there a way I can use pickray to position the note in the current version more accurately?
                                    Dan, what is involved in getting the transparent window or WebDialog working?
                                    • ashscottA
                                      ashscott
                                      I'm trying to modify Dan's script to make this a little more lightweight and to see if I can make a UI.messagebox appear whenever I'm editing multiple components as I seem to not notice the current notification in its current form.
                                      First thing, can't we chop out anything referring to groups as groups won't modify other groups that are derived from them? Like this:
                                      if inst.is_a?(Sketchup;;Group)
                                                  parent = inst.entities.parent
                                                  num = parent.count_instances
                                                  text = "Editing #{num} group instances"
                                                  puts(text) if debug
                                      That would also save the editpath query thingamajig from having a second "if" function in it (I think)
                                      Also, in order to get the UI.messagebox I'm trying to add in something like this:
                                            parent = inst.definition
                                                  puts {UI.messagebox("Editing #{num} component instances")} if debug
                                      But that keeps breaking the script....
                                      I feel like this should be really simple and it probably is - can someone point out how I'm misusing UI.messagebox?
                                      • Dan RathbunD
                                        Dan Rathbun
                                        messageboxes are modal (and it will suck to have to manually click a button each time you are editing multiple components.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          NO.. they did not update the API much at all.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            I would do the WebDialog first (as the transparent window would be only MSWIN.)
                                            BUT... per new policy... I am no longer doing ANY free development.
                                            Sorry guys.. but I got sick and NEED income.
                                            • 3 / 3
