    Internet not working
    28 Posts 10 Posters 2.6k Views 10 Watching
    • EscapeArtistE Offline
      EscapeArtist
      I understand that is not the first choice, but it's a great move. I have had several people complain about W8 "bricking" their computer or some part of it, then after installing W7 in the same system everything works perfectly.
      Why Microsoft does this is beyond me. Every other OS is junk... 95/SE, great! 2000/ME, junk! XP, great! Vista, pretty, but trouble. Win 7, finest MS OS to date. W8, right into the bin.
      Completely predictable, but why?
        liam887
        Right here goes, see you on the other side...
        VISIT MY ONLINE GALLERY
          liam887
          Didn't work still wont connect!
          • soloS Offline
            Does that machine show up on your network? say from your laptop,when you map your network does it show the new machine on it? it may just not be connecting to the internet but still working on the network, that will mean the hardware is fine but something funky with software.
              liam887
              Yes thats what I thought.
              Anyway I just took a trip to PC world and bought a USB network adaptor for Β£40. Everything is working fine now, just the mammoth task of installing all updates and drivers for the gazillion parts I have.
              I spoke to Ioannis and it seems I can quite easily transfer my license from my Mac to PC. Hopefully will try something later on Thea.
                EscapeArtist
                That's officially the first time I have ever heard of a NIC failure. Congrats on getting it sorted. Maybe eventually you can get an internal PCI slot NIC instead of the USB, your speeds will be much better. I have a stack here, but it would cost more to send you one than it would to buy one locally.
                  liam887
                  Yes finally have all the drivers loaded on. Thea is up and running (and registered) but unfortunately cant afford to transfer my Sketchup pro from my Mac to PC for $50. I will have to wait 5 weeks until I get paid again I am so disappointed 😞.
                  Interestingly my Windows experience number has dropped from 8.0 to 7.7 since downgrading the OS.
                  • soloS Offline
                    Because Windows 8 is actually leaner and faster than Windows 7, and because MS wants you to upgrade those greedy bastards. I run Windows 8 on my laptop and wife's surface tablet and it is screaming fast, IE 10 still sucks however, Chrome is very stable on W8.
                      liam887
                      yeah I thought as much, how annoying...
                      I also have a surface tablet, have been using it for a month now and havent put it down its super fast.I was also enjoying W8 for the last two days until it decided to break.
                      However one annyoing thing, the USB internet stick I bought today only works on W8 if you have less than 4GB of RAM, thats another reason why I had to downgrade.
                      In this day and age what desktops are running less than 4GB or RAM...http://mediapool.xpressplatforms.com/product-files/original-images/573334-178440.jpg
                      • N Offline
                        numerobis
                        @escapeartist said:
                        ...2000/ME, junk! ...
                        ME was junk, 2000 was great! (at its time) I had it for several years after NT4.
                        • N Offline
                          notareal
                          Not 100% sure, BKT maybe win7 and win8 experience numbers are not campatible. Anyhow, win8 is supposed to perform better when multithreaded apps are run.
                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                          • N Offline
                            notareal
                            Btw starting windows with safemode with networking can reveal if some other program is messing the network stack in normal mode. Did take while to recall, that some failed installation of a security program can mess system similarly.
                            http://support.microsoft.com/mats/program_install_and_uninstall/en-us may help...
                              liam887
                              No that wasn't the case. i did three clean installs with no software installed, even disabled the standard firewall and anti virus in both W7 & W8 but no luck.
                              I also brought the machine into work for IT to look at, would point to a hardware failure.
                              • N Offline
                                notareal
                                For me at work it's pretty rare to see hardware failure with NIC (IRL working as a team leader for the onsite IT support team for a organization with 700+ workstations πŸ˜‰). For this year I think I seen only one failed NIC (HP JetDirect card).
                                Anyhow HW failure sounds possible in your case. There is still a little change that some BIOS setting is causing the issue (example some motherboards will start dropping packets if two onboard NICs are enabled (some intel issue). Enabling UEFI boot also may mess NIC (another intel issue).
                                • 2 / 2
