New to Ruby and sketchup API, need some clarifications
Hi All,
I am new to Sketch up plugin development and also new to Ruby. I have experience with writing plugins for Autodesk products and other CAD platforms.
I want to do something very simple like getting distance between points(similar to tap measure tool). I took the code from the LineTool example and able to get an understanding of its inner workings. My dilemma is how to get the distance from the Tool class to my wrapper class when user is done picking two points or hits cancel.
Can I add some kind of observer when the tool is deactivated and read the length from the Tool class member variable?
Even better will API let me use the Tape measure command from my code ?
My second question is,
from reading the API I see that you can have only one glue plane per component, is possible to have multiple glue plans for same components so that I can attach multiple components to a component.Thanks in advance.
Tik. -
There is a Tutorial here about pickhelp if that helps.
To second question.
You do mean glue to face? Only 1 face per component I'm afraid.
If I'm wrong about this I will get very upset
However you can glue multiple components to 1 face. So maybe you can find a way
to work things around in different way.
I would like to add that different hierarchy's can be a solution to solve problem 2 maybe?
For ex:
For ex:
Thanks for pointing me in the right direction, i will take a look at the pickhelper class. I like idea of creating a hierarchy of components to make them work there. Once again thanks for the help.
Tik.
Glad to help!
For gluebehavior you can have a look in my code in "Hatchfaces".
(I don't know of any other scripts using that method..
)BUT! be adviced, I'm novice programmer so there might be lack of style and
best practices in there. -
@jolran said:
Glad to help!
best practices in there.I am very new to Ruby programming as well. I am having very hard time with structuring my code. Here is a small example related to one of my problems. I created a component with some constraints and place this component in the model. Before placing the component, I want to get the length of the component by clicking two points in SU and use that length for my component length.
To keep my code clean I am trying to separate my class into following folders or lets say module
Module 1:- this has the UI related classes like my toolbar and commands
Module 2:- this is supposed to have all the "Sketch up" api methods.
Module 3:- In this module I want to keep all my components related classes.
And this is how I always structured my plugin code in AutoCAD. With sketch up I want to do the same way but I am having hard with separation of code. In my API module I want to have a function lets say "get_length" which will call the tool class which does the mouse tracking etc and returns a length back when user is done picking two points or hits cancel. So far I have a class which is doing every thing i want to do related to getting the length. Only problem I am having is passing that length back to my api module when user is done. I am not sure how to get that length back, on the other hand I think I am over complicating this because of my lack of SU api knowledge.
Here is code snippet from my API class.
class Aqx_api def self.getActiveModel return Sketchup.active_model end def self.getLength aqxGetLength = Aqx_Get_Length.new getActiveModel.select_tool aqxGetLength end end # Class for getting the length which is based LineTool class from plugin examples. class Aqx_Get_Length # This class has code from LineTool. So I am not pasting every thing here. end -
I will be careful with givin codehelp, every time I do some guru come to the rescue and override my faulty advice.
Anyway, some ideas. Use if you like..
Unless you are making a Tool you don't really have to use Classes at all. Remember Sketchup API has already built in Classes. So you can make use of them. As long as you wrap your code inside modules.
But you do mention your want to build a tool. So you must then use a Class..I havent programed any Tool yet so I standby and let someone else give you pointers about
that.
BUT!, be careful with using codesnippets from the API. They are supposed to be poorly written, and sometimes even false. Same goes for some of the old Google provided plugins that reside in the pluginfolder.If I was you I would rather download a few plugin that reminds of what you want to do, from some of the more experienced experts around here. And have a poke around.
A good idea, (if you havent), is to download some of the Ruby code editors. With wich you can try snippets directly inside Sketchup. And also reload scripts.
There is also "Automatic Sketchup"(ebook), wich is a good startingpoint about using the API.
A bit old, though..
But it might help speed up the progress since you already have programming experience. -
A bit old, though..
But it might help speed up the progress since you already have programming experience.Thanks for your thoughts and suggestions. I tried few different IDEs including eclipse and others Ruby editors and ended up settling with NotePad ++ because that is the only IDE that is working with SketchUp bridge plugin. I have already downloaded "Automatic Sketchup" ebook and it has been a great help so far.
I am looking at different plugin's code to get an understanding of code structuring etc. From your experience is it a good idea to use core ruby classes with Sketchup and I am not sure how it will effect the working of plugin on Macs.
Tik
Notepad ++ is a good choice.
It's quite used around here I think. I use it to.
But I don't use bridge. I reload my scripts having robycode editor open all the time during developping. Can't remember why I do it this way
(Like I said. My experience is poor, so don't take what I have written as solid good advice.
I must stress that. I just jump in and ask questions or give advice when maybe I should
keep my mouth shut.
)At some point you must use the API ? Doesent matter if youre on Mac or not.
What I meant was that if there already exist a method in the API, one should use it.
Most likely it will be a faster method then what you will create in Ruby.Automatic Sketchup is really good for getting grasp of transformations and such. But you should really poke around other peoples scripts to get a feel of how to do things..
There are some recent performance tips here. And a few things to avoid.
