    Using mysql in plugin sketchup
    7 Posts 3 Posters 437 Views 3 Watching
      tom40
      Hello, I'm new in SketchUcation, I want acceded to a mysql database in a plugin.
      How to install mysql on ruby sketchup?
      Thanks.
      Thomas.
      • Dan RathbunD Offline
        Dan Rathbun
        Search: http://sketchucation.com/forums/search.php?st=0&sk=t&sd=d&sr=posts&keywords=mySQL&fid%5B%5D=180
        I'm not here much anymore.
          tom40
          Thank you.
          I found yours !Loadpaths.rb used ruby script for windows but I can not install mysql on ruby 1.8.6 (gem install mysql) I get an error "mysql Requires Ruby version> = 1.8.7 ".
          I am forced to use the same version (1.8.6) that sketchup?
            Dan Rathbun
            @tom40 said:
            AM I forced to use the same version (1.8.6) that sketchup comes with ?
            It is a good idea, but you can load another Ruby version easily on PC. (It's a bit more technical on Mac.)
            See: Ruby Interpreter DLLs (Win32)
            But you wouild also want to find a 1.8.7 full install to go with this.
            However... if you are writing a plugin for distribution, do not expect non-technical users to run SketchUp with a 1.8.7 Ruby.
            • H Offline
              honkinberry
              I have found that it is not worth the hassle. We instead access all such data through a WebDialog and data located remotely.
              --J
                tom40
                i am writing a plugin for distribution,
                do you think it is possible to import a component from a database?
                  Dan Rathbun
                  A component is a skp file that is loaded into SketchUp, from either a local directory (treated as a library,) or from a remote website.
                  Encapsulting skp files within another file container just adds unneeded complexity.
                  If you wish you CAN have a database that keeps track of the directory of components.
