    Model importing issue
    4 Posts 2 Posters 1.3k Views 2 Watching
      thunderhorse
      I'm new to this forum so sorry if a topic regarding this problem already exists. I did some search but found nothing so far.
      I use sketchup8 with sketchyphysics 3.2. When I import a model of a servo from gallery, I can't move it during the simulation. I understand there are some problems with copying joints and they stop working after pasting. But why can't I smiply move an imported model of a servo? I need it badly, because I'm trying to make a hexapod and do need servos there.
      Here's the link to the model I'm trying to import http://sketchup.google.com/3dwarehouse/details?mid=6999f0b2a0ddbfb67e20a5c42fa9976a&prevstart=0
      Any help much appreciated!
      • chriC Offline
        chri
        hi
        May be , you can do the opposite
        In first time , you load and open the file with the joint and in a second time , you copy your model inside .
        christian
          thunderhorse
          Well, I don't think it would change anything, cause when I open the imported model, I can't move anything there even when I make a simple ball on the floor...
            thunderhorse
            The issue solved - the imported model wouldn't move itself, but somehow, placed in a new group, it started moving. Strange things...
