    JSON in Ruby
    48 Posts 7 Posters 7.9k Views 7 Watching
      Myhand
      @oricatmos said:
      Is there a reason to avoid libraries like Yajl, because that's what I'm using. I should note that our plugin isn't distributed in any way and only used internally so far and I just put all necessary Yajl files in a sub folder inside our plugin folder. So that's not too pretty I guess, but it works fine.
      Thanks! I have not seen Yajl. Will give it a try. I tried
      http://flori.github.com/json/doc/index.html
      before but could not get it to work within Sketchup hence me writing my own class.
      http://www.keepingmyhandin.com/
        Myhand
        @dan rathbun said:
        Thanx for sharing.
        However it has one major drawback. You defined your class at the toplevel. This should be reserved for Ruby Core basclasses.
        In fact the way you wrote it, the methods never the ref to the self instance, so basically you wrote class (ie, singleton) methods, so it really IS a library module, but you mis-defined it as a class.
        Thanks Dan, this class is actually part of a module in my code, I just cut and pasted it out to show how it works. Thank you for the tips about libraries though, I have not explored this side of Ruby yet.
        You say that my methods are class methods. But I have done some tests and they seem to behave as object methods. i.e. each has access to the object's local state variables. I can also not call them as you would call a static method, i.e. JSON.escape().
        Why do you think my methods are static?
        Cheers
          Myhand
          Hi OricAtmos, I tried to get this to work but keep getting errors when trying to include the library:
          require 'yajl'
          fails with the following error:
          load "c:/temp/yajl_test.rb"
          Error: #<LoadError: c:/temp/yajl.rb:1:in require': no such file to load -- yajl/yajl> c:/temp/yajl_test.rb:1 c:/temp/yajl.rb:1 c:/temp/yajl_test.rb:1:in require'
          (eval):1:in `load'
          (eval):1
          How did you install the library?
          • OricAtmosO Offline
            OricAtmos
            I think it might have to do with the library search paths or something. I'll get back to you tomorrow with the details.
            • Dan RathbunD Offline
              Dan Rathbun
              require 'yajl'
              If you do not specify some kind of filepath, then the file must be in one of the directories listed in the $LOAD_PATH array.
              Ruby's require() first checks to see if the argument resolves to an absolute path, and if so, checks to see if the file exists, and if true, attempts to load it.
              Secondly, it checks to see if the argument is a relative path (incl. no path at all,) and if so, require() then iterates the $LOAD_PATH array prepending the base paths in front of your relative path. If it finds match, it loads the file, IF such a path is NOT ALREADY present in the $LOADED_FEATURES (aka $") array.
              What does the following LoadError exception message tell you?
              Error: #<LoadError: c:/temp/yajl.rb:1:inrequire': no such file to load -- yajl/yajl>`
              Answer: That "c:/temp/yajl.rb" on line 1, is calling require("yajl/yajl"), but no file named "yajl.rb", "yalj.so", "yalj.dll", etc., can be found, because it's a relative path, and there is no path containing a "yalj" SUB-directory in the $LOAD_PATH array, containing a file (of any valid extension that require() can load,) named "yalj".
              IF you simply copied the "yalj" directory into the SketchUp "plugins" directory, and typed require("yajl/yajl") in the SketchUp Ruby Console, it would be found. (Not to say that it would work, because it itself may have other file dependencies, such as Standard Ruby library files, which requires you to have a full Ruby installation, AND push it's library paths into the $LOAD_PATH array.)
              Understanding require() and load(), and how they use (or not,) the $LOAD_PATH (aka $:) and $LOADED_FEATURES (aka $") arrays, is Ruby 101 week 1.
              Click on the link in my signature, and follow the advice to collect docs. And just below my Newbie Guide, I posted the old "Pick-Axe" book. Required reading.
              I'm not here much anymore.
                Dan Rathbun
                OK Example:
                Assume your "plugins" dir, has sub-dir "myhand", which has a sub-dir "lib", which contains a file "json.rb"
                I recommend having your nested dir names match your nested namespaces, so you can remember the relative paths when it comes time to type a require expression.
                module MyHand
                  module Lib
                    module JSON # mixin module
                      def escape(value)
                        ret = ""
                        value.split("").each do |c|
                          if (/["\\\/\b\f\n\r\t]/.match( c ) )
                            ret << '\\' << c
                          else
                            ret << c
                        return ret
                      end # escape()
                    end # module JSON
                  end # module Lib
                end # module MyHand
                .. and in a plugin:
                module Author
                  module NiftyPlugin
                    # make sure the lib file is loaded
                    require("myhand/lib/json.rb")
                    # mix in the library module, as a nested module;
                    module JSON
                      # bring in public mixin instance methods
                      # as public module methods in THIS module;
                      extend(MyHand;;Lib;;JSON)
                    end # module
                    # use it calling a module method;
                    str = JSON.escape("\tHello World!\n")
                    puts(str)
                  end # module NiftyPlugin
                end # module Author
                OR ... using module_function() like the Math module does ...
                module MyHand
                  module Lib
                      module_function()
                      def escape(value)
                        ret = ""
                            ret << '\\' << c
                          else
                            ret << c
                        return ret
                      end # escape()
                    end # module JSON
                  end # module Lib
                end # module MyHand
                .. and in a plugin:
                module Author
                  module NiftyPlugin
                    # Use a library module function, via a
                    # local constant aliasing the library;
                    JSON = MyHand;;Lib;;JSON
                    puts(str)
                end # module Author
                  OricAtmos
                  Dan already explained more than I could have. He also wrote a nice ruby script to include additional folders in $LOAD_PATH. Read all about it here: http://sketchucation.com/forums/viewtopic.php?f=180&t=29412&p=342471&hilit=!loadpaths
                    Myhand
                    @dan rathbun said:
                    require 'yajl'
                    Thank you Dan for the detailed explanation and links to starter guides. I will review and try this when I get home tonight. One interesting point in this case though is that the only file called yajl.* is c:/temp/yajl.rb which is also the file that contains the
                    require 'yajl/yajl'
                    line. There is a a subdirectory called yajl, but no files named "yajl.rb", "yajl.so" or "yajl.dll" anywhere else in the yajl library distribution... So cannot see how adding the "c:/temp" path to $LOAD_PATH will find the file as it does not appear to exist.
                    Will let you know.
                      OricAtmos
                      Sounds like you don't have the complete library.
                      This is a list of files I have in my Yajl folder:
                      [...]\rubylibs\yajl.rb
                      [...]\rubylibs\yajl\1.8\yajl.so
                      [...]\rubylibs\yajl\1.9\yajl.so
                      [...]\rubylibs\yajl\bzip2.rb
                      [...]\rubylibs\yajl\bzip2\stream_reader.rb
                      [...]\rubylibs\yajl\bzip2\stream_writer.rb
                      [...]\rubylibs\yajl\deflate.rb
                      [...]\rubylibs\yajl\deflate\stream_reader.rb
                      [...]\rubylibs\yajl\deflate\stream_writer.rb
                      [...]\rubylibs\yajl\gzip.rb
                      [...]\rubylibs\yajl\gzip\stream_reader.rb
                      [...]\rubylibs\yajl\gzip\stream_writer.rb
                      [...]\rubylibs\yajl\http_stream.rb
                      [...]\rubylibs\yajl\json_gem.rb
                      [...]\rubylibs\yajl\json_gem\encoding.rb
                      [...]\rubylibs\yajl\json_gem\parsing.rb
                      [...]\rubylibs\yajl\version.rb
                      [...]\rubylibs\yajl\yajl.rb
                        Myhand
                        Yes OricAtmos, I think you are right. I took my version from here
                        https://rubygems.org/gems/yajl-ruby.
                        As I cannot install the gem in Sketchup I unzipped the gem file and took the files from the lib directory. This gives me the following files which is clearly not complete.
                        C;\Temp\lib\yajl
                        C;\Temp\lib\yajl.rb
                        C;\Temp\lib\yajl\bzip2
                        C;\Temp\lib\yajl\bzip2.rb
                        C;\Temp\lib\yajl\deflate
                        C;\Temp\lib\yajl\deflate.rb
                        C;\Temp\lib\yajl\gzip
                        C;\Temp\lib\yajl\gzip.rb
                        C;\Temp\lib\yajl\http_stream.rb
                        C;\Temp\lib\yajl\json_gem
                        C;\Temp\lib\yajl\json_gem.rb
                        C;\Temp\lib\yajl\version.rb
                        C;\Temp\lib\yajl\bzip2\stream_reader.rb
                        C;\Temp\lib\yajl\bzip2\stream_writer.rb
                        C;\Temp\lib\yajl\deflate\stream_reader.rb
                        C;\Temp\lib\yajl\deflate\stream_writer.rb
                        C;\Temp\lib\yajl\gzip\stream_reader.rb
                        C;\Temp\lib\yajl\gzip\stream_writer.rb
                        C;\Temp\lib\yajl\json_gem\encoding.rb
                        C;\Temp\lib\yajl\json_gem\parsing.rb
                        Where did you get the library from?
                        Cheers,
                        myhand
                          OricAtmos
                          I don't remember where I got the Windows binaries from. Perhaps I still have a bookmark in my web browser at work, but right now I'm at home and can't have a look. But since I have access to our project repository from home I can offer you this:
                          Dropbox - 404
                          (dl.dropbox.com)
                            Myhand
                            Dropbox - 404
                            (dl.dropbox.com)
                            Thanks OricAtmos! Will give it a try.
                              OricAtmos
                              Did you get it to work? Unfortunately I've been unsuccessful in finding out where I got it from.
                                Myhand
                                Sorry, I got a bit tied up with trying to solve the MAC bug in my Material_Maintenance Plugin.
                                Thank you, I have now got it to not throw an error, but my test code does not seem to serialise objects, so will need to read the library docs to see what I am doing wrong
                                ` require 'yajl'
                                h = {"key1", "val1", "key2", "val2"};
                                obj = ["Hello", "world", "I am here", ["where", "what", "are", "you"]];
                                class TestClass
                                @name = nil;
                                @adress = nil;
                                @list = nil;
                                def initialize(p1, p2)
                                @name, @adress = p1, p2;
                                @list = [1,2,3.01,-4.35];
                                t = TestClass.new("Richo", "37 Scotland Rd, Buckhurst Hill, IG9 5NP");
                                obj = ["Hello", "world", t, "I am here", ["where", "what", "are", "you"]];
                                str = Yajl::Encoder.encode(obj);
                                puts str;`
                                Produces
                                ["Hello","world","#<TestClass;0x144d9cc0>","I am here",["where","what","are","you"]]
                                Instead of the
                                ["Hello","world",{"@list";[1,2,3.01,-4.35],"@name";"Richo","@adress";"37 Scotland Rd, Buckhurst Hill, IG9 5NP"},"I am here",["where","what","are","you"]]
                                I would expect and which is what my simple JSON Serializer produces.
                                  Myhand
                                  Hi OricAtmos,
                                  I got it to work now thank you. It seems that it can only serialise Hash and Array objects though, which is good enough for most cases I guess. Given the non-trivial install and given the fact that it uses binary libraries, I suspect it will not work on a MAC either without libraries built for that.
                                  I will therefore continue with my simple JSON encoder, which while probably much slower, is simple to install and should work out of the box on a MAC as it is pure RUBY. It can also encode standard objects which can be useful.
                                  Thanks for your help in getting this working though. I will keep it in mind if I ever have to do large data sets.
                                    OricAtmos
                                    All right, I wasn't aware Yajl isn't able to work with arbitrary objects. I was only using it to encode/decode hashes with simple values and arrays.
                                      Myhand
                                      Hi guys,
                                      I need some help. I have run into problems creating a json encoding where a string contains a single quote char. e.g. "Betty's pie shop"
                                      somehow ruby creates a new char which replaces the y and the '. You can see this by executing the following command:
                                      puts "Betty's pie shop"
                                      and I get
                                      Betts pie shops pie shop
                                      if you past this into an editor that supports UTF8 you see that a special char has been added into where the y and ' was. Also note that the last bit of the string is now duplicated.
                                      I can escape it, but this is then not a valid json string as json does not allow you to escape the ' char.
                                        driven
                                        May be your encoding... only fails with single quotes here
                                        Betty's pie shop
                                        nil
                                        > p "Betty's pie shop"
                                        "Betty's pie shop"
                                        nil
                                        > print "Betty's pie shop\n"
                                        Betty's pie shop
                                        nil
                                        > print 'Betty's pie shop\n'
                                        Error; #<SyntaxError; (eval); compile error
                                        (eval); parse error, unexpected tIDENTIFIER, expecting $
                                        (eval)
                                          Dan Rathbun
                                          @myhand said:
                                          ... somehow ruby creates a new char which replaces the y and the '. You can see this by executing the following command:
                                          and I get:
                                          %(#008000)[>> Betts pie shops pie shop]
                                          At the SketchUp Ruby Console:
                                          ` puts "Betty's pie shop"
                                          >> Betty's pie shop
                                          puts "Betty's pie shop".inspect()
                                          >> "Betty's pie shop"
                                          puts "Betty's pie shop".inspect().inspect()
                                          >> ""Betty's pie shop""`
                                            Dan Rathbun
                                            s = %q(Dan's friggin' advice, "Hey, use Ruby's % lowercase 'q' interpretive delimiter. It's a great help when your bleepin' strings have "'" and '"' characters in them!")
                                            %Q and % is a double-quoted string. You can choose any 2 delimeters you want.
                                            name = %$MyHand$
                                            str = %q{I want some quotes right "HERE"! Let's go.}
                                            • 3 / 3
